My xerox is just giving me nightmares with the usb host to host communication.
1.whats so special with the usb cable cant i just put in a normal male to male usb cble.please advise
recently after like 10 restarts due to the usb host to host communication error.now its hanging while in the middle of printing.
please help on how i can elliminated these errors that are causing delays in mywork
SOURCE: phaser 7400
i have a phaser 7400 printer when i turn on the printer it say cyan led error turn off printer and turn it back on. It keep on giving me this message what should i do. Another thing is that a gear on the waste cartridge is broken is there a way i could fix it without getting a tech to come look at it. It alway say waste toner is full, ( replace it) which i already did. What should i do?
SOURCE: Lexmark X 1270 Can not Print
I may be a bit late with this but it worked for me. Uninstall your antivirus, remove any parental controls and disable your firewall. Then, reinstall the printer and download a 2008 version of your anti virus and re-enable your firewall. I haven't reactivated the parental controls just in case it all goes pear shaped.
SOURCE: Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Hello.
I am a Support Engineer with Xerox Scanners.
If scanner is stopping @ 98% is normally due t oa communication problem. Make sure USB cable is conencted to rear of PC ,and cable is no longer than 6ft..
We also have an extensive support site and knowlegebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
