Question about Water Heaters
Steam injector Hi. Can you tell me how to remove the cones from a 4'' scale model traction engines Pemberthy style live steam injector. I don't want to try pressing them out until I'm sure I know what I'm doing, as obviously I don't want to damage them by Incorrect procedure. Many thanks. Mike.
  • 332 Answers
They unscrew,, go to home depot on get a strap wrench and tighten it around and turn to the left, they will come off they are just decoration,, when you reinstall them put a little faucet grease on them and tighten them back up
Posted on Jun 21, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
The thermostat on the wall is not working-no response to pressing any keys
Hi John:
I'm confused. Thermostats on walls typically control room temperature, and the thermostats for water heater tyemperature are typically set where they can not be easily adjusted. Can you tell us what make and model of heater you have, and what you are trying to do? We'll try to help.
Apr 03, 2015 | Water Heaters
Instant hot water tap - hot steam but delay and no hot water
This unit is set way too hot. The steam is pressuring the water out of the unit.
Feb 18, 2014 | Emerson InSinkErator C1300 Chrome...
Pilot Orifice
Okay you don't ream pilot injectors hence the 3 inch pilot which is now no good to you nothing to be done with that .
Take you manual to heating / plumbing shop tell them you need a new injector for you pilot block they might be able to sell you just the injector or a new pilot block Most pilot injectors are the same size . Or get you gas fitter back to replace it as the injector was only blocked and needed a clean . in 40 years of gas fitting I have never reamed a injector .
Jun 04, 2017 | Bosch 1600P-NG AquaStar 4.3 GPM Indoor...
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
How do I wire around upper heating element until I can get an other one to replace it?
Question posted under marathon electric water heater.
Marathon is 240Volt dual element non-simultaneous water heater.
Non-simultaneous means that upper part of tank has to reach temperature before power is sent to lower thermostat and element. So if upper element is bad, then water heater has no hot water.
http://waterheatertimer.org/Replace-anode-rod.html#audibleBW
1) You need to by-pass upper element without by-passing upper thermostat.
2) You should never by-pass upper thermostat because it has ECO-reset protection.
http://waterheatertimer.org/How-water-heater-thermostats-work.html
3) Open following link for image of wiring:
http://waterheatertimer.org/images/Marathon-wiring-700.jpg
4) Take photo of your wiring in case color code is different on your specific model
5) Look at upper thermostat.
Remove yellow wire from terminal 2 on upper thermostat, and cap off temporarily.
Remove red wire from terminal 4 on upper thermostat, and move it to terminal 2 on upper thermostat.
6) For more effective operation, look at lower thermostat.
Remove black wire from lower thermostat terminal 1 and move wire to terminal 2 on lower thermostat.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Rheem MR105245 Marathon Electric Water...
I have a Rheemglas 250 litre electric hot water system. It seems to have stopped working. Is there anything I can try to get it working again? Otherwise I'll need a technician but hoping it's...
Make sure you have power to unit. Check the breaker in your breaker panel and look around unit for a timer or disconnect that may be having problems. I don't know if you are electrically inclined so if you are scared to take off front panel, don't do so. If you believe your breakers and/or any disconnects etc., are on and working, you can remove the screws holding the inspection panel on and press the reset button on the thermostat. There may be insulation covering the thermostat. The thermostat should have a plastic cover on it shielding the live wires while making it possible to press the reset switch. Again, if you are electrically inclined, you can check for power at the thermostat. These are the simple things you can check. If you reset the button, within about 3 to 5 minutes, you should here noise from inside the unit if it is working.
Jun 05, 2011 | Rheem 81VP6S/430126 Water Heater
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
74 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
