Question about Vehicle Parts & Accessories
Ford ranger speedo- not working trip- odome still working
Neddle hanges to the left does not run on cable need speedo to work
  • 71 Answers
There are free speedometer apps for smart phones.
Posted on Nov 08, 2014
Yea my odometer and trip is analog and there not working on my 96 ford ranger 4cy all other guages work i was wondering if it is on the rear differental that sensor back there or where its at cause its...
If I am correct that vehicle uses a speedo cable that goes from the instrument cluster to the transmission.
If your speedo is not woorking you may have a bad cable or gear which is on the end of the cable and can be accessed by removing cable from tranny which is held in by a bolt and clip.
If your speedo is working but your odometer is not than you have a problem in the cluster itself.
You can have it repaired at a certified speedo shop or replace it with junkyard unit.
Jul 17, 2011 | 1996 Ford Ranger SuperCab
I have 1988 ford ranger an speedmeter had stop working before i got it where does the speedmeter hook up at
look at the tranny under the drivers side of truck....speedo cabe is that large cable fastened to the tranny via a circular ring at it's base. it may be unplugged---if not will need to be lubed at both ends and where it is exposed under the hood......use wd 40 and work it in wearing protective gloves..
Feb 28, 2010 | 1988 Ford Ranger
Speedo not working ford maverick diesel
Sounds like your speedo cable went out. This is a fairly easy fix, just a cable that screews from the transmission.
Oct 07, 2009 | 1993 Ford Ranger SuperCab
"93 c1500tranny/engine swap l460e to 700r4/V6toV8- No Speedo/odom
Slide under the vehicle and see if the cable to the speedo gear was re-installed. It may just be hanging there. If it is not a cable make sure you plugged in the connector to the speed sensor.
Aug 26, 2009 | Chevrolet C1500 Cars & Trucks
Speedo/electrical
Well, it sounds like the loose cable goes back into the transmission -- that would be your speedometer cable.
This cable would not cause electrical problems, but something pulled it from the transmission and may have, at the same time, pulled an electrical wire loose. I would check the transmission and surrounding area for loose wires.
May 28, 2009 | 1987 Ford Ranger
Speedometer works somestimes
it is the gear in your speedo cable and the cable is not hard to change it normally goes to your front wheel back to your transmission put the truck on ramps put a stop or something behind the rear wheel and then you will see what i am talking about.
Feb 08, 2009 | 1997 Ford Ranger SuperCab
The dashboard
You may have a couple separate concerns. The fuel gauge if it is on empty may have a hole in the float. The speedometer odometer and trip meter is probably a broken gear in the speedo assembly. If the speedometer itself works it is getting a signal from the speed sensor.
Feb 02, 2009 | 1998 Ford Ranger SuperCab
1996 ford ranger odometer / trip stopped working
Since your speedometers work, the problem is in the gearing to the trip and mileage odometers. Simple problem, major pain to fix but, remove instrument cluster - you'll have to remove speedo cable to get it out. Use the old Mark I eyeball to check for broken parts. Might even have to drop steering column - disconnect air bag first!
Jan 30, 2009 | 1996 Ford Ranger SuperCab
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
