Question about Food Processors
Lost disc stem need new one
Need to order new disc stem part #210204-100
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
Does any one know where I can get a disc holder to a black and decker cfp-10 food processor.
Are you talking about the "disc stem" that holds the grater disc on? I need one too -- mine cracked down the middle. I LOVE this food processor and hate to get rid of it because of this one problem.
Aug 14, 2012 | Food Processors
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Apr 13, 2009 | KitchenAid KFP750 Food Processor
I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Dec 26, 2008 | KitchenAid KFP750 Food Processor
I need a part!
Try this page, and feel free to have it shipped in. Also, the exploded parts view will help you find your part number.
http://www.mtmc.co.uk/prodtype.asp?cookiecheck=yes&PT_ID=12706282
Feb 29, 2008 | Black & Decker FP1000 PowerPro Food...
Install Cuisinart stem cover
I was able to replace my pieces thru Small appliance.com I ordered new parts and the directions on how to remove the old stem and put the new one on.
Put a little vaseline in the rim of the new stem. Use a wooden block and a hammer or rubber mallet and lightly tap the new one into place.
Cuisinart called two weeks after the fact to say I have to send them the machine.....
Oct 17, 2007 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
23 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
