Question about GE Cooktops
GE Profile Gas cooktop JGP 641 igniter is not working
Igniter is not working
MNfisherman
  • 11896 Answers
SOURCE: does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Posted on Apr 01, 2009
  • 105 Answers
SOURCE: Ignition of burners is difficult and uncertain.
remove the burner caps, or heads and check all of the ports to be sure they are not clogged. Also be sure that when you put them back that they go into the correct positions.
Posted on Apr 09, 2009
  • 530 Answers
SOURCE: Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
Posted on Jun 02, 2009
SOURCE: how do I remove the spark igniter when replacing a burner bowl
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
Posted on Jun 28, 2010
heatman101
  • 43501 Answers
SOURCE: GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 21, 2010
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
Ignition stoped working on my ge profile gas cooltop
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 17, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
How do I remove the spark igniter when replacing a burner bowl on GE JGP 636 gas cooktop
Jan 23, 2010 | GE 30 in. JGP326 Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Does not ignite
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
Cooktops Logo
82 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
