Question about Admiral 32 cu. ft. Washer
Lnc6760 cu. ft. capacity - Admiral 32 cu. ft. Washer
What is capacity of my whirlpool duet ggw9250pw1? I don't see the answer identified. thank you
The Whirlpool Duet ggw9250pw1 looks like it has a 7.0 cu. ft. capacity. This is based on two different sources. The first has the GGW9250PW1 in a list of parts for 7.0 cu. ft. capacity Whirlpool dryer models. See http://www.appliancepartspros.com/search.aspx?model=whirlpool%20duet%207%200%20cu%20ft%20super%20capacity%20electric%20dryer .
Similarly, the related electric dryer, GEW9250PW1, is shown as having a 7.0 cu. ft. capacity at AJMadison.com: https://www.ajmadison.com/cgi-bin/ajmadison/GEW9250PW.html .
I hope this helps.
Nov 27, 2017 | Whirlpool Dryers
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy StarĀ® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
What is error code E3
If you have a gen one (finger ice maker) it means the th3 sensor is open. You will want a trusted technician to tackle this issue.
Mar 04, 2015 | Frigidaire FGTC2349KS Gallery Series 22.6...
What is the cubic ft capacity of this old model
If you no longer have the manual that came with it, you can always measure the dimensions internally and do the math to calculate the cu ft capacity. Do do this multiply all the measurements together. Then write that down. Take and multiple 12*12*12 and write that number down. Take first number and devide second by it. That should tell you the cu ft capacity of your oven or whatever you want to determine.
Nov 26, 2014 | Kitchen Ranges
LG LFC21760ST Beeping Constantly again. Last time it cost me a fortune to replace the computer board. Isn't there a cheaper way to stop the sound?
I would suggest starting with the easiest troubleshooting tip first. Try unplugging it for 10 minutes and plugging it back in. Most (modern) appliances will reset to factory defaults when they are unplugged for a few minutes.
May 29, 2014 | LG LFC23760SB Three Door French Door...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have a KELVINATOR KCI 21 B Fridege/Freezer and would like to know the volume/cubic capacity of both compartments . . . . .
This is called a 21 Cubic Ft unit.
The actual specifications are:
Freezer Capacity: 6.5 Cu. Ft.
Refrigerator Capacity: 14.5 Cu. Ft.
Total Capacity: 20.9 Cu. Ft.
Apr 18, 2010 | Refrigerators
Admiral 32 cu. ft. Washer Logo
52 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
