Question about 850 960 S90 V90 92 - 97 Anti Theft Alarm Relay
Hood misaligned hood hinge wont work on passenger side. I will bend the hood metal if I force it.
How do i take the entire drivers side door off of my 2011 HHR? Its a DIY project n cant afford what the insurance isnt covering. My car was T-boned and wont even open. Basically smashed shut.
You need to have the door forced open before you can access the hinges and remove it.
Remove the interior door trim and the door can be unbolted at the door hinge area. Examine the door on the undamaged passenger side before you do anything.
Nov 04, 2015 | Cars & Trucks
I have a vintage K5A mixer that belonged to my mom and has always worked perfectly. I just shipped it cross country and I think it may have been dropped on its side. The flat beater now hits the side of...
There is no lateral adjustment apart from brute force to bend the tongue on the bottom of the motor housing that engages into the pedestal at the hinge. I can\'t see what else could be bent laterally. You may be able to overcome it by tilting the chrome bowl engagement ring in the pedestal base, a washer or two between the chrome ring and the pedestal with one of the 3 screws through it. Trial & error.
Feb 21, 2014 | KitchenAid Food Mixers
Where is the blower motor resistor located
Hi, the blower motor resistor is located under hood on passenger side on firewall. If need more help just re post. Thanks dodge tec
Jan 02, 2011 | 1992 Plymouth Voyager
I have a Swift SM80 microscope and we are seeing double images. I can't seem to adjust
Sometimes the eyepiece tubes get out of alignment. To check for this, look through the microscope. As you are looking through the scope hold the eyepiece tubes and see slightly "flexing" these tubes with your hands has an affect on the image. If your head is the problem you will be able to flex the tubes until the image is clear. You won't need alot of force. Do not use enough force to bend or break the weak metal. If this works your eyetubes and or head are misaligned. Unfortunately, once a head has been misaligned like this it is not practically repairable.
Nov 01, 2010 | Swift SM95-90HF Stereoscopic Dissecting...
Hood replacement & adjustment
Replace All. Used would be the cheapest way. And keep hood all the way locked!
Mar 16, 2010 | 1998 Toyota Corolla
Hood blew open, now shut and can't get open, what to do. Have tried everything to get it open, need solution
Is the hood bent just enough where it wont latch? Try to put a 2x4 near the back part where the hinge or shock go and close hood gently andpush gently until hood bends back to shape and will close
Mar 09, 2010 | 1997 Ford Explorer AWD
Window on driver side of 2003 Camry stuck. Had
You can adjust the door latch by aligning the male and female portion of each. This can be adjusted by loosening the screw and aligning it. And finally when aligned, tighten the screw. Unless otherwise if the door hinges are loose, such that the doors are misaligned, then, you have to replace the door hinges. Or put a bushing at the door hinges to keep it
aligned. This will correct the defect.
Nov 15, 2009 | 1992 Toyota Camry V6
How to change hood struts 1989 Pontiac Trans Am?
you first have to take off the hood (2 bolts on each side where the hood meets the hinge) then take off the hood hinges (3 or 4 bolts on each side on top of fender) and after all that your hood hinges should be off. on each end there will be a metal retainer that holds the strut on the hinge, carefully pry these off with a screwdriver and install new struts, bolt the hinges back on and finally the hood
(have a friend help you lift the hood off)
Mar 11, 2009 | 1989 Pontiac Firebird
Help
make sure the lid is making contact with the switch when the lid is closed, listen closly for a "click" noise upon closing the lid, if you dont hear anythig the lid is no tbeing recognized as closed therefore will not enter a spin mode for safety reasons.somtetimes by pressing down harder on left side of the lid you can get it to startup. if this is the case a simple solution may be in order, after lifting the lid make sure the scrrws attaching the lid to the hinges are tight, then if you place your hand under the left rear side of the lid you feel the lid actuator( its the opposing side to the door hinge) with a nutdiver( or similliar hollow pointed metal object) slide it over the metal hinge and apply force to slighty bend to toward the reare of the machine( as you apply pressure the lid will want to push against you , thast s normal its the hinge your bending) after slighty bending now see if tyou can here the click?
Oct 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
New Cornu Fe Stove - Oven door pops open
I had the exact same issue with my Cornue Fe (only on the right hand side oven). The other symptom I noticed was that the door itself didn't close as smoothly as the left hand side oven.
Take a look at the alignment of the "post" sticking out from the oven relative to the spring loaded catch on the door. These need to be *very* well aligned vertically in order to keep the door closed as it heat cycles. You'll notice that the post has a depression at the end of it (furthest away from the door). The door catch has an upper and lower spring loaded roller that is supposed to "catch" on both sides of the depression. If you are misaligned vertically, then only one side of the catch will be applying sufficient force to the depression.
In my case, the post and the catch were misaligned by about 4-6mm. In fact, I noticed that repeated opening & closing of the door was actually causing some wear on the upper roller of the catch. To fix, I needed to raise the door, which was accomplished by adjusting the hinges.
I removed the door from the oven, which can be done by removing the screws on the hinges. The hinges consist of a bottom & top knob that slot into the door (similar to the way refrigerator hinges work). The hinges themselves are made of ~1/4" metal (could be stainless, but it's relatively soft stainless). I put the lower hinge in a vise (appropriate covering to prevent scratching) and *gently* bent it up to adjust the door upwards. Putting it back together required some help (the door is heavy), but after a bit of work it was all back. Thankfully the alignment was right the first time. This whole process took about 20 minutes.
In my case, I suspect that either the wife or kids had put too much weight on the door at some point and bent it out of alignment. The problematic door had about 4-6mm of "play" between the top and bottom hinges prior to my adjustment--the working door had zero "play". You might want to check to see if you have any such play before you do this work (you can either look at the hinge itself or simply lift up on the door at the hinge point to see if it moves). If you don't have this same play, but you do have misalignment, then you'll need to adjust both top and bottom hinges.
The other possiblity is that you might have a weak spring in the catch mechanism. You can check that by gently pushing a flat head screwdriver in between the two rollers and feeling for how much force is required to separate them.
Of course, you can also just call the La Cornue service folks and have them check it out.
Mar 21, 2008 | Kitchen Ranges
850 960 S90 V90 92 - 97 Anti Theft Alarm Relay Logo
14 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
