Question about KitchenAid Kitchen Appliances - Others
Stop alarm beeping
Loud fire like alarm before the toasting is complete
4 Suggested Answers
SOURCE: kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Posted on Feb 28, 2010
SOURCE: My airpurifier stopped working completely,
If you have a filter, than replace it. Look up the brand name of the unit and try to find an on-line manual.
Posted on Oct 14, 2010
  • 17326 Answers
SOURCE: Electrolux slide-in gas range & oven - broil was on making toast. Caused fire in oven, fire subsided but oven still beeping 30 minutes later. How to stop? And is oven ruined?
Unplug it from the power for a minute. Try again. IF no luck post the make and model. Might have to replace themostat
Posted on Feb 06, 2017
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
Waring TCO650 toaster oven - how to turn off or down the beeping
I found it! In the manual that came with the toaster (and not the one online), I found the following instructions:
1. To turn the indicator beep OFF: Press both [TOAST] and [BAGEL] keys and hold for 5 seconds.
2. to turn the indicator beep ON: Repeat the above process.
Note - if you lose power or unplug the unit, the beep comes back, so keep these instructions handy. :)
Dec 01, 2012 | Waring Tco650 Professional Toaster Oven
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
Jul 09, 2012 | Haier Dryers
Can you turn off the annoying beep when toast is
Hate to tell you this, but from the looks of their manuals on the similar Australian model, then no.
"When the toasting cycle is complete, the toaster will ‘beep’ to indicate that the toast is ready. No need to wait while the toast cooks."
Dec 03, 2009 | Breville CT75XL 4-Slice Toaster
Aopen ax34 tamper alarm--how to reset????
I don't think that board actually has a tamper alarm in the bios, password security yes but I saw no mention of a tamper alarm. Besides, a tamper alarm won't stop the pc from booting, it just lets you know that the case has been opened....sorry. I think you likely have a mainboard/ram issue.
First thing is to clear the bios. Here's how. Right beside the floppy connector, there is a jumper labeled 'JP14'. Please do the following
  1. Turn off the pc and remove the ac power cord.
  2. Remove the atx power connector from the mainboard (from power supply).
  3. Locate jp14 and move the jumper from pins 1 and 2 to pins 2 and 3. Wait 10 seconds.
  4. Put jp14 back to pins 1 and 2
  5. Reconnect the atx power connector.
Or you can just unplug it from the waal and remove the bios battery for an hour.
sa code
Try to fire it up again. If it still won't boot, then let me know the number of beeps it makes and the pattern to the beeps ie: one long beep then another long beep or 1 long beep then 2 short ones. These beep are actually telling you what the problem is.
Hope this helps! Post a comment and let me know how you make out.
Aug 24, 2008 | AOpen AX34-U Motherboard
Kenmore he4t washer
I had the same problem. The "fire alarm" sound is coming from the silver panel behind your washer. The panel is vibrating loudly during the wash cycle. A Sears repairman solved this by taking a small piece of cardboard (cut from a box) and wedging it between the side edge of the panel. He operated the washer's cycle and adjusted the tightness of the wedge until the loud sound stopped. It did! Hope this helps you!
Jul 01, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kitchen Appliances - Others Logo
43 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
