Question about Stihl 021 023 025 Ms210 Ms230 Ms250 Chainsaw Handle Bar
How to adjust chainsaw oiler on stihl MS230
Can you adjust bar oiler?
  • Stihl Master
  • 1,807 Answers
You cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Posted on Mar 07, 2015
3 Suggested Answers
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
  • 100 Answers
SOURCE: how do I adjust the chain oiler for a Stihl 043?
if it doesnt have a flow screw.u dont. pull pump plate off and clean and sometimes replace pump.
Posted on Oct 22, 2012
Need repair and service manual for Stihl 012 chain saw engine
google the stihl web site and if there are manuals available ,you will find them there.
May 27, 2015 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Stihl MS250 overheats and burns out engine.
the carb fuel augments mite be set to lean or gas oil mixture not mixed rite
Apr 11, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
No oil to chain stihl ms250
Oil pumper oil gear, needs to be adjusted or replaced. Check out a video how to replace.
Nov 29, 2013 | Stihl 021 023 025 Ms210 Ms230 Ms250...
How to remove stihl 023 handle bar?
There are three mounting points. You need to remove the screws behind the plug caps with a T27 bit. Then, the tank should separate from the crankcase and you can pop the AV mount from the crankcase to replace it.
May 24, 2012 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Dont no how to ajust the ioler for the bar oil uses a tank of oil to a half tank of fule burned
what brand saw? Stihl saws are made to run Stihl oil. If you are runnin other oil, the viscosity wont be the same as the pump is designed for, and the oiler may pump more then it should. The oil adjustment screw should be a single flat head set screw on the underside of your saw near the sprocket. Alot of saws are not equipped with an adjustable oiler. Professional saws and larger displacement saws will have the feature.
Sep 15, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Too much oil is being delivered on the chain, how do I adjust the oiler on my Stihl 038av super?
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Nov 25, 2010 | Garden
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Hello, my stihl 017 chainsaw is over oiling the bar, is there any adjustment I can perform, thanks, Gareth.
No oiler adjustment. Sorry
http://www.stihlusa.com/stihl_ownersmanuals/017_018_Manual.pdf
Are you using bar oil or something lighter? Stop by your local Stihl dealer (leave your saw in the car), give him a latte, and chat. He might have an idea or 2. He will not be chatty on any weekend or if there is a perspective sale in the store, HTH
Lou
Jan 19, 2010 | RTO Spur Sprocket For Stihl 017, 021...
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl 021 023 025 Ms210 Ms230 Ms250 Chainsaw Handle Bar Logo
208 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
