Optiplex gx620 need to bypass administrator login
I'm having problems getting past the administrator password and in order for me to become the new administrator or even a user I need to know the original admin password it's ok if I have to start from scratch
    Problem Solver:
  • 30 Answers
There ar programs for your problem - look for ERD-commander.
Posted on Apr 14, 2014
SOURCE: lost password to 170L administrator
Try password =password
or administrator or admin or Admin, Administrator, or ntadmin, NTadmin
and let me know
Posted on Jan 01, 2009
  • 135 Answers
SOURCE: can reinstall or format drive
Recover your password with Slax OrphCrack Live CD.
Posted on Feb 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: I forgot my Administrator Password
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/r.../locksmith.asp
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
  • 3940 Answers
SOURCE: dell optiplex gx620
There is a Jumper on the motherboard to reset the system Password.
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/advfeat0.htm#wp1117484
Posted on Feb 24, 2009
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
I just want to get on to my emal page
Click on the start button, select Internet explorer, type www.gmail.com in the address bar and hit enter (return) Enter your email address and password to login.
Nov 20, 2013 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
My gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
I forgot my password for my dell optiplex 740?
I think you are running on Windows vista or 7, in this case you have to remember the Administrative password. Reboot your PC and before Windows logo arrive press F8 couple of times, a list of option will arive, choose "Safe Mode" you should be able to login with an Administrative account. From there go to ccontrol panel> accounts .. delete the account and add a new one.
In case if you forgot the Administrative password you have to hack into the system and delete the account:
How To Reset Windows Vista Password
Jan 29, 2013 | Dell OptiPlex 740 PC Desktop
I have forgotten my administrator password and when i boot the machine, after it loads and gets to the welcome screen, i am asked for a password. i have totally forgotten it and cannot log on. i have...
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Aug 18, 2011 | Dell OptiPlex 780 MT PC Desktop
Bought a new Canon Pixma MG6150. Have followed the directions up to page 29. Have put the CD into the CDROM drive and clicked on Msetup4.exe, my admin screen pops up, I type in the password and get the...
According to your problem you can't install the driver of your printer. For your information to install any software or hardware you must need administrative privilege. If there require administrator password to login and you can't login also after giving password then first check the password you have typed is correct. Some time guest user can't do the all thing after get administrator password. Then you must need to login as administrator. You can try to start the setup by right click on the setup.exe and selecting Run as Administrator. If it doesn't help you then you need to change the user permission from administrator account.
Apr 26, 2011 | Canon Office Equipment & Supplies
I put in a password for the main Administrator of the computer like 5 days ago. I thought I remembered the password but when I type it in it won't accept it. Is there a way to bypass that password?
Try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use third party software from Hiren's Boot CD to reset your login password http://www.hirensbootcd.org/download.html
Jan 24, 2011 | Dell OptiPlex GX620 PC Desktop
Forgot log on password and user name
Pls remove the Hard Drive and connect with another working PC as secondary .Login through administrator and open the drive where the OS installed which one not able to login and follow the path.
Windows/system32/config/SAM file
delete the SAM file .after that connect the Hard drive as Primary and check hope fully it will resolve.
Nov 21, 2009 | Dell OptiPlex 170L PC Desktop
I lost password
If this in Windows password and xp, there a lot of utility to bypass or reset its password to nothing. If you can access the administrator account its password is only blank you will just hit enter. And upon entering the account change/reset your password for the user account you always use.
Try to activated the administrator account login in safemode.And login to that account if it can.
If this doesn't help let me know.
Apr 23, 2009 | Computers & Internet
Acer Aspire M1100 Desktop - lost password, can't login in User Login. Is there a way to bypass the password?
If you're having trouble logging into Windows, you can attempt to use the Administrator account to edit/remove the password of the user login. The Administrator account is hidden by default while in normal mode. You'll need to boot the PC into Safe Mode and login as the Administrator account. Follow the below steps:
  1. Reboot the PC and before the Windows boot screen appears, tap the F8 key about once per second.
  2. Eventually you'll be faced with a screen asking you how you want to boot Windows. Select Safe Mode.
  3. You will see some dll, sys, and com files scrolling down your screen, this is normal. Eventually the PC will boot up and you'll have a login screen with your User Account(s) and a new account, Administrator. Select Administrator.
  4. As long as you haven't, in the past, altered the password for the Administrator account, you should be able to simply click this account and have it log you in. If it requests a password, you might try "password" (without quotes) for the password.
  5. Once in, Navigate to Start -> Control Panel -> User Accounts
  6. Select the User Login information that you're not able to log into and remove the password for the account or change it something you know.
You can now reboot the PC normally and be able to log into this account without a password or with the password you created.
Mar 05, 2009 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
