Question about Plantronics Radio Communications
Buzzing on Plantronics s12
I use my phone for 2 hours and everything is fine. Then all of a sudden I get a buzzing noise that last for 10-15 seconds, then it is clear again, then the buzzing noise will come every 3 or 4 minutes. I know my connection is fine. I have been using the headset for months without a problem. I have been experiencing the random buzzing for the past two weeks. The other person on the other end can hear the buzzing too. What can I do to fix it? I've bought a new s12 headset and I'm still having the same issue.
SOURCE: It's on but earphone not working
Solution number one does work. Just tried it and presto!!, all working again.
Posted on Jul 08, 2007
  • 3 Answers
SOURCE: samsung wep 200
Headset microphone may be off. Just press the volume up buttom and keep it pressed for 4 seconds or so, the pcs will beep twice to turn the mic on.
Posted on Sep 19, 2007
  • 579 Answers
SOURCE: Viking Micro noise
The noise is probably from the high-voltage transformer. When it is overloaded, the excess magnetic field it produces vibrates its wire coils. Odd that it only happens for a brief time. It is either defective itself (in which case it may go a long time) or it is getting overloaded by the magnatron/capacitor/diode on its output (in which case it will get worse shortly)
Hope Ya Fix it
Posted on Jan 08, 2008
SOURCE: Buzzing Noise
Did you all buy your sets off ebay or some other non-motorola manufacturer.....I know it doesn't seem like it but chances are you have a counterfeit motorola...Most of the ones on eBay or other sites where you buy from people are COUNTERFEIT....there are ways to check. go to motorolas website and type in
counterfeit
theres a PDA file to check if urs is
Posted on Feb 10, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
Posted on May 28, 2009
Testimonial: "It was the compressor. Bought a new Amana and it's great! Hate Sears still;)"
My 96 jeep grand Cherokee v6 was running fine then all of a sudden won't turn over, and there's a buzzing noise coming from inside somewhere.
buzzing noise how long does it last? about two to 3 seconds is just the fuel pump which is normal. could be the starter. starter the lights will come on but no crank. dead battery nothing comes on just loud clicks.
Dec 09, 2015 | Jeep Cars & Trucks
My Plantronics Voyager Legend has a constant buzzing noise, it does not work at all. When I turn it off or on, it does not matter, just a buzzing noise.
I just had this happen to me. Like yours mine just kept buzzing and the on and off switch had no effect. It just kept buzzing.
The way I was able to fix it was to reset the device by holding both the mute button and the call pick up button until the buzzing stopped. It took only 3 seconds to fix and it immediately began to work. When I switched it on the buzzing was gone and it was working again.
I hope this helps anyone as I didn't see and answer to this issue online anywhere and had to figure it out myself. Take care.
Mar 18, 2013 | Plantronics Voyager Legend
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Our uniden hand held has developed a loud buzzing noise
I Had the same problem.
I found out what it was. The buzzing sound came from the AC/DC charger. I changed it and everything is working fine now !
Try with a AC/CD adaptater putting it on the right voltage and check if it's working without this buzzing sound.
Have a good day !
Sandy S.
May 28, 2010 | Uniden Cordless Phone
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
Apr 08, 2010 | 1998 Lexus Gs 300
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
My phone line has developed a loud buzzing noise
Try with a AC/CD adaptater puting it on the right voltage and check if it,s working without this buzzing sound.
Have a good day !
Sandy S.
Apr 30, 2008 | Lands Phones
Radio Communications Logo
29 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
