Question about 4imprint Veneto Automatic Wine Opener | 6Pcs $49.99 Each
I cannot get it to work. I put in the batteries, checked the batteries, but no response to when I turned it on.
It is the Black Series, Shift3
I have a shift3 black series deck turntable/converter, which lists compatibility with windows XP and vista (!)... I need to use it with my Toshiba Satellite which has windows 8. I dont even know were to...
I guess the first thing you need is the USB cable. Tahe a good photo of USB output of your turntable and wisit any computer prts shop. They will help you select the cable you need.
More complicated issue is the software. Probably it had an XP/Vista driver but you don't have it
You should connect it and try if your computer can recognize something
If no way, try exploring Sharp's website for contact/support
http://www.sharp-world.com/support/disclaimer.html?secna
May 04, 2015 | Shift3 Shift 3 The Black Series Deck USB...
How do i get the battery to recharge
Could possibly be a bad battery but if you have a voltage meter check voltage ouput on your charger. They have a habit of going bad quite often. Rich
Oct 02, 2014 | Sharp Shift3 Lookbook Wireless Reader
I'm not getting any power to my lenovo 3000 j series desktop.
Hello, please try the following:
1. First is to check your power supply. Try to look if the power supply is functioning, if the fan turns so it is okay.
2. Try to remove the CMOS battery and put the cmos jumper setting to reset mode.
3. Remove the Memory card.
4. Plug your Computer and standby it for about 3 minutes.
5. Return all the devices that you remove.
6. Switch back to normal the CMOS.
7. Turn on your computer and your done.
Hope it will help you.
Mar 15, 2012 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Completely dead, no response, had been fine, nothing happened to it
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 25, 2010 | Canon PowerShot A710 IS Digital Camera
I bought my son a shift3 usb video camera for
Did you try changing the batteries? if that doesn't work you can return it to the store do you have the sales receipt?
Feb 12, 2010 | Kohls Shift3 Pocket Video Camera with...
The key isnt starting the car
Absolutely. Could also be that the smart key has a dead battery or has been compromised by moisture, etc.
Can you still lock & unlock the car with the smart key? If so, the battery is not dead, and you should look next at the ignition itself. Is there any response when you put the key in? Can you turn it? Are there signs that your battery is drained (dim/no lights work, etc)? If you are getting no response when you put the key in and you can turn it, and it still works to unlock your car and you can verify that you have battery power, start by checking your fuses. The ignition and starter fuses would be the first to check.
Nov 07, 2009 | 2004 Mercedes-Benz C32 AMG
Can't Turn ON keychain
I'll tell you but that will cost you $9.99.
Jul 18, 2009 | Innovage Shift3 MP3 Player
Camera does not respond
I suggest you open the battery compartment and check the connections on the battery. It may be that they are a little dirty, preventing proper electrical connection, in which case you can clean them with a little cotton bud and perhaps some methylated spitits.
Mar 15, 2009 | Casio Exilim EX-Z50 Digital Camera
Manual for telephone shift3
i can not get a dial tone on my shift3
Dec 22, 2008 | Lands Phones
4imprint Veneto Automatic Wine Opener | 6Pcs $49.99 Each Logo
65 people viewed this question
Top 4imprint Home Experts
john h
Tom Chichester
Are you a 4imprint Home Expert? Answer questions, earn points and help others
