Question about Gateway MX3215 Notebook
I have a network and wireless issue needs to be fixed
I am a tech. got 3 laptops I am trying to network and get back on the wireless side of my network...My vista is an HP and it wireless right now...My XP gateway mx3215 is suppossed to be wireless and right now it is hotwired via cat5 to the linksys router..the last laptop is a XP Pro and it has a linksys wireless card that is not being read so it is cat5 connected to the router,too...
Need these 3 machines to see ea other and I am Hamachi on the xps.....no one can see each other on the network...What do you think ????:)
  • 21 Answers
First thing to do is make sure they are all in the same workgroup and that all three have identical user accounts and passwords.
Once you've done that, make sure all of them have sharing enabled for the areas you want to share of each drive.
This should do it. Let us know if you need further assistance.
Posted on Jun 18, 2009
Brother i have just opened a wireless network but my wireless network is not working properly. Can u plz contact me for some help i shall be very thank full to you if u do this favour for me. Thanks...
Troubleshooting issues with wireless connectivity can be tricky. There are a bevy of potential causes for drops in the connection, slow-downs in throughput and sporadic signal loss. As such, it's best to take a shotgun approach, throwing a number of possible fixes at the problem and hoping one sticks.
Check if your laptop's wireless switch or button is turn on - look around the laptop in front, back or sides. Sometimes you might touch to turn off accidently and you don't know. Many laptops have the wireless light indicator, check if the wireless light is on and blinking.
Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the wireless, which is to control the wireless connection of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, touchpad etc. You will need to hold down the Fn + F8 combination keys together, in this example the Toshiba laptop's wireless setting.
  • 3
    Check Network connections; make sure the laptop connection is not 'disabled'. It should has the gray color if it's disabled. Right click on it and enable it.
  • 4
    If none of the above works, you will need to enable the Wireless Zero Configuration in services.msc (type this in from Run command), or you can see it this way: Right click My Computer -> Manage -> Services and Applications -> Services.
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJNokX7
  • 2
  • 3
  • 4
  • Read more: How to Fix Wireless Not Working in Laptop ' eHow.com http://www.ehow.com/how_6066601_fix-wireless-not-working-laptop.html#ixzz1LiJ8lq45
    May 07, 2011 | Computers & Internet
    Cannot the wireless internet setup
    Hi kschmerer,
    I understand that you are not able to setup the Wireless Network Connection in your Computer.
    To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
    You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
    Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
    If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
    To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
    This should fix the issue.
    Please post back if you have any questions or require further assistance.
    Thanks for using FixYa.
    Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
    I just bought an Acer Aspire One and cannot connect to my wireless Internet. I have had several conersations with the techs at Acer and I have spent nearly an hour with Verizon, even a 3-way convo with...
    You can try these things if haven't yet. Make sure the adapter is turned on. Find out if your wireless router is putting out a signal. In My Network Places network tasks run Windows setup wireless network wizard. In Network Connections right click the wireless adapter and see if it is enabled.
    Jul 17, 2010 | Acer Aspire One PC Notebook
    My wireless connection quit working and then a couple weeks later I could not even connect to the internet at all. What went wrong? Computer is 2 yrs old. Can it be fixed or should I start shopping for...
    That laptop has a known issue with the wireless network card not being recoginzed by windows. You can verify this by going into the device manager and seeing if the wireless network card is in there, more then likely it won't be.
    Best option is to call HP Tech support and ask them about that known issue and see if your laptop can be covered by there recall. You have so much time before the recall won't cover your laptop.
    Here is there tech support number: 800-474-6836
    They are open 24/7
    I remember that HP computers or laptops have a 1 year warranty unless you get an extended one and recalls can last up to about a year after the warranty expires, call and see if they can get your laptop covered under the recall.
    Dec 19, 2009 | HP Pavilion dv6000z Notebook
    Adapter issues
    Foildemon, If you are still needing assistance with any of your Consolidated Communication services please contact our tech support staff at 1-800-480-0080 opt 1. We are available 24 hours a day 7 days a week for your convenience.
    sincerely,
    your CCI tech support staff
    Dec 17, 2009 | Zhone (6218-I2-200) Router
    Please help me get my wireless settings
    If you have windows XP on the laptop then perform the steps below:
    1. Right click on My Computer icon and go to Manage.
    2. Go to Services then go to Service and Applications.
    3. Double click on Wireless Zero Configuration.
    4. Change the Start Up Type to Automatic and click on Apply.
    5. Click on Start and press OK to close the window.
    6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    7. Right-click on the wireless Network Connection icon and select 'Properties'.
    8. Go to the 'Wireless Networks' tab.
    9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
    Now please perform the following instructions to connect to the wireless network:
    1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
    2. Right-click on the wireless Network Connection icon and select 'Properties'.
    3. Click on the 'wireless network' tab.
    4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
    5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
    6. Look for the SSID (aka Network Name) of the Wireless router or access point.
    4. Highlight the SSID from the list that you want to connect to.
    5. Type the security Key here and click on the 'Connect' button.
    6. You should have successfully established a wireless network connection.
    For Vista on the laptop:
    1. Click START, Click Control Panel then click classic view in left hand side menu.
    2. In the main screen, open up NETWORK AND SHARING CENTER.
    3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
    4. If you see any name in the list, please select the name and click remove.
    5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
    6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
    7. This should setup the wireless network.
    I hope this information allows you to resolve this issue.
    If I have helped you, please help me, and rate this suggestion the highest FixYa
    rating. If you cannot rate this post with the highest rating, then please
    comment to this post and I will try to help you further.
    Regards
    Anand
    Aug 30, 2009 | Acer Aspire 3000 Notebook
    I have a wireless network- 2 laptops plus 1 desktop usually connected wirelessly. Today, I hit the reset on my Tmobile Dlink router and I am unable to log on of my laptops back onto network. When I use...
    try unplugging the router for about 5 minutes and then plugging it back in. I would also unplug the modem at the same time, then plugging the power back opn for the modem and then plugging the router back in too. should reset ur issues
    Jul 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
    Unable to get Wireless to turn on
    Sandy,
    What was the earlier problem?
    Do you think it is/was/might be related?
    How did you get past the issue? If you formated, you have to go through "Software Setup" find it at Start, All Programs, Software Setup. (tc1000) or if you restored with the factory discs (tc1100) then it should be done. If a tech "restored" your tablet with other than the factory restore discs, then Q menu may be impaired or nonfunctional.
    Is the card actually there?
    Are the cables connected?
    Is the card the original hp card? Some others will not work with the Q Menu.
    Go to hp.com, navigate to the tc1100 support page and download all drivers or recent updated drivers.
    Install the updates and you should be fixed.
    HP will sell you restore discs for $10.72 (thats what I paid last fall) that will install the correct drivers for the unit. Cheap at twice the price. You will need a keyboard (USB generic will work if you don't have the original detachable) and an optical drive (USB CD Drive) basically to do this.
    My friendly local tech is at $50 for basic service, and if you can back up to another PC (cat 5 cable connection is fastest) or a card, then a reformat never hurts a thing, kills many troubles too!
    Best Luck, Blaino
    Apr 23, 2008 | Compaq tc1100 Tablet PC
    Wireless netowrking issue with the laptop
    Try to configure the a static IP address for the laptop on the router. This is done buy finding the LAN MAC address(computer) on attached devices, then designating it a default IP.
    Had this problem on my mums work computer when i updated the firmware on my Netgear router.
    Jan 08, 2008 | Acer Aspire 5100 Notebook
    Gateway MX3215 Notebook Logo
    69 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
