Question about Konica Minolta Bizhub C550 Color Copier/printer/scanner
Cod c 3925 not printing - Konica Minolta Bizhub C550 Color Copier/printer/scanner
  • Konica Minolta Master
  • 6,696 Answers
Model number would help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 12, 2017
Erro cod c 3925 no copy or printing - Konica Minolta C244e. Color Copier/printer/scanner
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Try once if it does not work DO NOT TRY AGAIN. It is dealing with the fuser unit it CAN CATCH ON FIRE ruining a perfectly good day. Get a tech out to check the fuser unit and replace it.
Try this site for a ball park figure of the fuser unit if you are not under a maintinance contract.
Precision Roller Printer Toner Cartridges Parts and Supplies
Mar 10, 2016 | Konica Minolta Office Equipment & Supplies
Tip
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret <pswd>"-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
on Sep 05, 2011 | Computers & Internet
Asp ie 3925 video driver
Here:
ftp://ftp.work.acer-euro.com/notebook/aspire_3935/vista/Drivers/VGA_Intel_v7.15.10.1624_VISTAx86.zip
Jun 28, 2012 | Acer TravelMate Computers & Internet
Acer model video driver asp ie 3925
Download the video and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Jun 28, 2012 | Computers & Internet
How can i get license code for spyware doctor?
try this
License Name: Yale Wachsmann License Code: C113-54B7-3925-E2B1-ABAA-FDEA-C8E3-7DE0-3ED0-C768
Sep 18, 2010 | Computers & Internet
Reset drum cod
The codes are C Auto C Auto display off, press 24 print 7 print , 00 will display then press C twice.
May 06, 2009 | Sharp AL-1642CS Copier
AUDIO DRIVER FOR ASP IE 3925
plz try this link www.sharewareconnection.om
Apr 02, 2009 | Computers & Internet
Konica Minolta Bizhub C550 Color Copier/printer/scanner Logo
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
