Question about ASUS M2N-MX Motherboard
ASUS M2N MX SE Motherboard
How to connect 2 HDD one SATA and one IDE for virus scan Instead of SATA drive IDE is taken as Primary even after all jumper setting in IDE GB segate
  • 21 Answers
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Posted on Jun 18, 2009
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
MY computer is not booting when i connect my new DVD.
Please make sure that your HDD and DVD ROM drives are getting detected in BIOS. Are you using IDE or SATA drives?
May 19, 2009 | ASUS M2N-MX Motherboard
My computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
May 16, 2009 | ASUS Computers & Internet
M2N-MX SE PLUS SATA PROBLEM
Do your have windows installed on a ide drive?, cos if this is the case you have to install the sata hdd drivers.
Mar 27, 2009 | ASUS M2N-MX Motherboard
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
ASUS M2N-MX Motherboard Logo
217 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
