Question about Supersonic SC1964UM Mp3/cd receiver am/fm usb
Volume button is stuck on high - Supersonic SC1964UM Mp3/cd receiver am/fm usb
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
My TD-26 turns on and it has high level volume. It"s don"t like me. How change it when is it turns on and has medium level volume
the volume has the issue, I suggest you try to clean it up with the right liquid, or try to see if it is stuck!
Jun 04, 2014 | Santai TD-V26 Portable Mini Digital...
TV volume goes to loudest on it's own
It sounds like you may have a stuck micro button (volume button on tv) . You might try to push the up volume button on the tv several time and try to get it unstuck (if in fact that is the problem). Also sometime I have had situtions where the board holding these switches on the inside of the t was broke and had to be soldered and repaired.
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 12, 2013 | Sharp 25R-S100 25" TV
My volume is stuck on high. How do I fix this?
Open the Control Panel, Sound, adjust volume, OR Click on the Sound Icon in the Tray Notification Area, adjust sound. OR reboot the machine.
Jan 07, 2013 | Acer Aspire 7250-bz600 Laptop
KS4102: Remote volume buttons won't work . Button is stuck down for the "lower volume" so I am only able to use "high volume" which is too loud for comfortable listening. Do I need replacement remote, and...
You can disassemble and clean the remote, this might help.
Clean the rubber keypad with ethyl alcohol and cottonwool, also clean the contact tabs on the rubber keypad and on the circuit board (don't rub the contacts too hard when you clean them, you don't want to damage the conductive coating).
Also clean well the housing, especially the holes on the housing where the rubber buttons protrude.
The holes (and the rubber buttons) get dirty with use and this often causes the buttons to get stuck.
I had to "repair" several remotes with stuck buttons, and simple cleaning did the trick.
I hope you can get it fixed...
Regards
3rq8 (Triarcuate)
Sep 13, 2009 | Televison & Video
Volume stuck in high position
Make sure that the volume + button on the front is not sticking. If it is spray a little WD40 on it and free it. Then you should have control over the volume.
Apr 05, 2009 | RCA F32648 32" TV
Can you repair the volume buttons on a Rio Forge
My switch broke, too. The player is easy to take apart, and you can see where the switch broke, but it's too small to sodder back yourself. I just switched to a headset with an adjustable volume slide on the wire. My player was stuck at a LOW volume, so I had to touch a wire across the switch leads to "click" back up to being stuck at a high volume. Now i use the headphone line to adjust from there.
Dec 29, 2007 | Rio Forge Sport Digital Media Player
Volume control
Is there a sliding switch on the handset or on the left side of the machine?
Oct 09, 2007 | Panasonic KX-FPG376 Plain Paper Thermal...
Volume buttons stuck inside
hi , first i want to say that the tv is not a game it is hazard set very high voltage inside so if you don't have any experience please dn't try to , but you can do it your self just took outlet off and took case off and try to draw the chasses towards you to behind then look inside to the place of the buttons you will see aplastic tips which will push the volume switches that are soldered on the chasses and with your fingures try to push out the plastic tips to relocate it to the original state it is too easy and the please try to be away from the cable that is fixed to the screen cause high voltage is it, refix chasses and cover and give me high rate insted of £40:) regards
May 06, 2007 | Sanyo DS24425 24" TV
Supersonic SC1964UM Mp3/cd receiver am/fm usb Logo
11 people viewed this question
Top Supersonic Audio Players & Recorders Experts
Martin Buenrostro
Martin Buenrostro
Level 1 Expert
ELECTREPAIR USA
ELECTREPAIR USA
Are you a Supersonic Audio Player and Recorder Expert? Answer questions, earn points and help others
