Question about Dewalt Tools & Hardware - Others
I am from England and had a dewalt framing nailer that was air powered with depth set,quick clear for jams,and depth set is there a similar model in the USA! Also you do not rate the dewalt as you seem to have a lot of problems with them
rowdy45176
  • 2176 Answers
SOURCE: Is there any way to
I am assuming that a nail got jammed? If so unplug air to tool, remove the rest of nails and turn it over. try to find a flat piece of steel smaller than the nose where nail goes and gently tap the driver back up and remove jammed nail. If the driver is broken that is a different fix. Hope this helps
Posted on Dec 09, 2008
rowdy45176
  • 2176 Answers
SOURCE: Need cleaning instructions for ITW Paslode Impulse
I would recommend you go to Paslode.com and under support there is a section for cleaning of these tools. I can tell you how to do it but it is indepth. What kind of cleaning solution do you have? You can't just use anything to clean them. Also the red light on means a failure. Does the fan work? Does it have fire and it also means that the battery is weak. They also have a good troubleshooting section on the site. Let me know if I can help further.
Posted on Feb 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Posted on Feb 21, 2009
Idaho_Biker
  • 32 Answers
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
Posted on Mar 27, 2009
jj505
  • 195 Answers
SOURCE: framing nailer not setting nails
Dear cjcoolair,
No need to replace any parts. There should be and allen screw type adjusment somewhere near the front plate where nails exit so as to adjust depth,may be black plate with arrows up or down depending ---loosen screw,push up/down as needed,tighten test and reset as needed.
Please rate.jj
Posted on Apr 05, 2009
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
Inlet air preasure
Dewalt guns use between 70 and 120 psi. I use 100 psi on all framing guns when testing, however the nailer will last longer if you use lower pressure (only whats needed to drive nail into work, depending on type of wood) . When too much pressure is used, extra force is absorbed by the lower bumper and nose area of gun.
The address below is dewalt service and has all the info about your nailer. Just enter the model number and look for pdf file. Check your model number for safety recall. Good luck
www.servicenet.dewalt.com
Jun 22, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
Dewalt D51850 framing nailer leaks air continuously
You could have broken internal parts but more likely you have broken or worn o-rings inside the nailer. You can go to the Dewalt service site at, http://servicenet.dewalt.com/, search for your model number and get a good breakdown of the nailer and order the parts you need to rebuild it. If you replace any o-rings, replace all of them.
May 25, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
Common problems dewalt clipped head framing nailer
there is NO easy solution for this, but unplug air and get a pair of safety glasses and a punch and try and knock the driver up into the tool away from the nail or if it is just jammed try and pull the nail out. You didn't really specify where the problem is. Let me know if you need more assistance.
Jan 05, 2012 | Dewalt D51822 Clipped Head 2Inch to...
How do you set the depth on a Bostitch N57c coil nailer besides lowering the air pressure
Hello. The only way to set the depth is to lower or raise the air pressure. The rn175, however does have a depth setting feature which you may find useful for your app. http://www.protoolreviews.com/reviews/air-tools/bosch-roofing-nailer-rn175
Jul 01, 2010 | Stanley Bostitch Coil Framing Nailer
Press the trigger and all we get is a puff of air
could be driver stuck with jammed nail or the firing valve is stuck in the head. If this is a Dewalt tool go to Dewaltservicenet.com and type in your model number for a breakdown before removing the cap.
Nov 08, 2009 | Dewalt Round Head Framing Nailer D51845
Similar "bolt not retracting" problem
Dewalt offers a Oring kit for this tool part #610773-01 for 27.37 and they have instructions on installation. Also you can go to Dewaltservicenet.com and download a schematic for this tool. It has a stuck valve or similar damaged part to cause this. Let me know if you need more assistance
Jun 28, 2009 | Dewalt Round Head Framing Nailer D51845
Is there any way to free driver blade on nail gun? my gun is the dewalt 20 degree framing nailer
Dec 06, 2008 | Dewalt Round Head Framing Nailer D51845
D51844 Framing Nailer won't fire
Adjusting the depth of the nail also changes the amount of pressure that is applied to the trigger pin. This is not actually a problem with the adjustment, however indicates that the orings in the gun are not completely sealing or is lacking lubricant. Adjust depth so that maximum pressure is asserted against the trigger pin. The trigger pin must be pushed all the way in very quickly to fire the gun. Test by removing the trigger and depressing the trigger pin by hand all the way in quickly. Enjoy
Dec 05, 2008 | Dewalt D51844 Framing Nailer
Tools & Hardware - Others Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
