Question about Jenn-Air JFC2089HE French Door Refrigerator
Whiney buzzy noise - Jenn-Air JFC2089HE French Door Refrigerator
    Master:
  • 439 Answers
Could be a fan needs oil or replacing. Find a fan outside and a fan inside.
Posted on May 27, 2015
Whiney noise
Diagnosing a noise like this is nearly impossible over the internet, have a local shop look into this noise.
Jul 19, 2012 | Cars & Trucks
I have a whiney noise when excelerating with my 1996 Mazada MX-6. Someone suggested that it could be a power steering pump. Is that possible? Why would that cause a noise when excelerating?
It could be any part that spins and has a bearing including the power steering pump, air condition compressor, alternator, water pump etc., even if the belts are too tight!!! The easiest way to find problem is by removing each belt and see if the noise is still there.
Jun 11, 2011 | 1990 Mazda MX-6
Van makes noise when i accelerate
if its a whiney noise probably gearbox going or if its a clunky kind of sound probably steering rod ends or steering linkage...just had both done on my own van
Jan 10, 2011 | 2001 Chrysler Town & Country
04 4x4 loud whiney noise in 4 high. Is that normal?
no its not something wrong here ,would need to drive it ,ask local mechanic to have a drive then post what he says
Aug 21, 2010 | 2004 Lincoln Navigator
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
Rear diff noise
We have to be sure where the noise is coming from, a advise you or ask someone to do the following tests:
  1. jack your both your rear tires and make sure its stable. turn your tires either manually or by shifting gear into reverse and try listening to any humming or whiny sound or vibration not only from your rear differentials but also your transmisssion and independent transfer case.
  2. Be sure it secured and will not move and will not squish you under.
  3. also check on your rear propellers, differentials for excessive play
  4. If you determined where it is coming from, check on your gear oils.
My own assesment from what you have just told us, is I would also check on your clutch system, because whiney noise only exist when you are backing up the car. I hope you would pin point which part is causing the whiney noise to save you all the headache of having it repaired.
Comment after you determine where it is coming from.
Thanks for dropping by fixya
Nov 24, 2008 | 1994 Suzuki Samurai
Whiney noise as i drive Volvo V70, even when i turn the car off
this sounds like the bearing in the thermostatic cooling fan has worn possibly lift bonnet with car started keep hands out and look for a fan on the front of the radiator the are usually black plastic and are easily replaced and become noisy when worn hope this is helpful glenn....
Nov 23, 2008 | 2002 Volvo V70
Jenn-Air JFC2089HE French Door Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
