Question about Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder
Batteries are charging fine but once you run the chair it drains the batteries
My chair has been sitting for three years now won't take a charge and run did the main battery die
Time for a new battery. The worst thing you can do to a battery is let it sit for a long time. Once the battery was activated it is best to keep it charged while not in use. Use a trickle charger while storing your chair.
Aug 26, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
How do i know if my jazzy power charger is working
Without the charger the batteries would go dead. You could put a voltmeter across the batteries and you should read more than 28 VDC while charging.
Nov 16, 2012 | Electric Jazzy 1115 Power Wheelchair
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
A few months ago, I got 2 new batteries for my Jazzy and the first month everything was fine. Lately the batteries have been losing power abnormally fast. We were told to keep the chair plugged in at all...
Jeff WRONG!!!!!! I would demand that the dealer give you new batteries (they should be under a six month warranty anyway) You are to NEVER repeat NEVER leave the charger or chair plugged in all the time. The most you should ever have to charge the batteries is overnite or 12 hours. Never leave the charger plugged into the chair more than 24 hours. Doing so might even void the warranty. Tell that dealer or however told you that to take a hike or at least know what they are talking about. Have them read an owners manual (if they can read) under care and use of batteries Geez it just upsets me to have people give out such bad information to their customers. Now the batteries need to be replaced and when you get new ones charge them before you use the chair then charge then everynight if you use the chair daily if you don't use it daily make sure it is fully charged when you put it up and at least once week (if idle that long). I would recommend using your chair daily for a little while to run the batteries down some and then charging overnite for the first 20 days that you have the new batteries this will break them in. Hope this helps and sorry for the rant
Sep 25, 2010 | Jet Health & Beauty
What are the cost od replacenebt batteries? The offf board has alreadtv been replaced under warrant it is only one year old AND USED VERY LITTLE IN THE HOUSE, IS IT A LEMON?
Did you purchase the chair or Medicare? This chair has small batteries that need tender loving care If you do not use it often you need to charge the chair at least once a week and always put it up fully charged. Once the batteries get weak then no chair charger will pick them up. Check with a local battery warehouse or similar supply store for 2 12/12 batteries. Hope this helps
Aug 16, 2010 | Pride Go Chair Travel Power Chair
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Quickie Wheelchairs Quickie Aspire Power Wheelchair Cane Crutch Holder Logo
44 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
