Question about Nikon COOLPIX L810
Motor shuts of when warm
After motor warms up shuts off in about 2 min hit the key and starts immediately and then shuts off again after app. 2 min
    Guru:
  • Nikon Expert
  • 362 Answers
There are a couple of possibilities. Your camera has a circuit that detects excessive temperature and turns the camera off to protect it from a total failure. Either something in your is drawing too much electrical current (possibly due to a short circuit) or the temperature sensing circuitry is defective. In either case, I would send the camera in for repair.
Posted on Oct 23, 2014
Why does truck shut off when warmed up about 10 min?
I would be looking at the coil and ignition module. Check the plugs first for corrosion. Since coils don't come back to life that quick. I would remove the module and have it checked, call first. Some parts stores can still check them.
Nov 27, 2015 | 1994 GMC Sierra
Shuts off after start up
You need to have the ECU checked for any codes.
Oct 26, 2013 | Mazda MX-5 Miata Cars & Trucks
Engine cut out
Has anyone checked fuel pressure cold and hot ? Check engine light on ?
Sep 26, 2013 | Chevrolet Lumina Cars & Trucks
Engine shuts down after 2 min - Gsxr 750 1997
Bad ignition coil. You can try to find the OHM specs and test it but that is what happens when you have a failing coil.
May 08, 2013 | Motorcycles
Kia Sorento V-6 start-up difficulty
You probably should perform a fuel pressure test to see if the fuel pressure is bleeding off of the fuel rails when the engine is shut off. If it is, you could have a bad fuel pressure regulator or a bad check valve in the fuel pump module (which will require replacement of the module).
One way to test for this condition without any tools is like this:
cycle the key ON, wait about two seconds, then OFF, wait about 2 more seconds, and back ON again. Repeat his 3 or 4 times before turning the key to the CRANK position. If the engine starts immediately every time you do this, then the hard starting is definately caused by the fuel pressure bleeding off.
Apr 21, 2012 | 2011 Kia Sorento
Car starts and runs. Once it's warmed up, the engine shuts off tried to start it again motor turns over but will not start. Wait a couple of hours then the motor will start again and then will shut off...
Wouldn't think sensor or computer problem , more likely an ignition module . When it dies pull a plug wire an check for spark ,i think you will find no spark . Just from my 30 years of diagnosing GM vehicle's this has been the #1 cause of a start an run till warm an dies an wait 20 min . to an hour an it starts again problem. But without testing to know for sure that would be a guess . Having a qualified an certified repair technician diagnose the problem is always the best idea.
Dec 12, 2017 | 1993 Saturn SL1
The engine runs for less than 2 mins and shuts off
could be oil low cut off , dirty air filter ,check fuel filter.
Oct 05, 2009 | Craftsman Garden
87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
Jul 28, 2009 | 1987 Ford Taurus
Nikon COOLPIX L810 Logo
42 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
