Traveltek sx 1068
The charger plugin on my traveltek will not make a connection to charge.
I have a traveltek tablet10.1 capacitive multi-touch screen android jelly bean 4.2.2 1.0 tnx processor & 1 gb ram I can't get it to come on at all even with charger is there a light to show it's charging cause it hasn't been on for months so what do I do please help
Posted on May 14, 2017
2 Suggested Answers
kbdesign
  • 370 Answers
SOURCE: charger to computer connection intermittent
You will have to take it to a techie and have a new d/c jack installed on the motherboard. Easy job, but want to know what you are doing. About $60us in my market for jack and labor.
Good luck, and please rate this response.
Posted on Mar 15, 2009
Does the traveltek tablet have capability to run Netflix through it?
You didn't mention your Model, but this site seems to indicate it may be possible. It is always possible to get better answers if you give the Model... http://traveltekusa.com/traveltek/faqs/video-problems-using-netflix-with-the-traveltek-sx1068-tablet/
Jun 11, 2014 | Tablets & eReaders
Charging problem
Have you tried another charger? Try to take out the battery, then plug in the charger again. There may be something shorting out the computer whenever you connect your charger
Apr 17, 2014 | Toshiba Satellite Pro L300 Notebook
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
Charger
man you have to repair it
because the failure is in charging base
there is detector to detect if the charger is connect or not these one are damaged or faulty
go to any trusted repair shop
Jan 10, 2014 | Samsung Galaxy GT-S5570
One fine day after low battery indication i plugin phone for recharge, it was well connected and showing charger plugin indicator on phone. phone was also working but percentage of battery was not...
You can try with this procedure, Try to charge another battery in this phone with another charger, if the battery got charged then there is an issue with your charger and battery, if it gives the same problem, then you have to get fixed your phone from repairing shop or your cellphone service center, it seems that the charging IC of your phone is not working properly which needs to be replaced, they will check the whole motherboard of your phone, and will fix the problem, if the set is in warranty claim it as soon as possible .
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA! Regards, BA
Feb 11, 2011 | Cell Phones
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
Will not charge the battery or input any power. The battery is fine. I think its a loose connection internally where the power adaptor/charger plugs in. need a manual to show how to dissasemble and replace...
Here's a direct link to the service manual for this laptop:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01293339/c01293339.pdf
Based on my experience troubleshooting such kinds of problems, you will need to get the motherboard out of the case to be able to replace or tighten the power connector.
Nov 30, 2009 | HP Compaq 6720s Notebook
Charger is no longer working
Oh, believe it or not. My computer use to do the same thing all the time. Just take the prongs on the plugin and bend them outwards slowly. This will make a tighter fit in the outlet.
Jun 11, 2009 | Acer Aspire 7720-4428 Notebook PC
When i plugin chargar mobile show usb connect
Insert your charger pin completely into the phone. Then phone will show charging now.
After also if problem not clear then you have to reset the seetings and try it again.
Thanks,
Rokr_E6
Jan 12, 2009 | Motorola Mobility ROKR E6 Smartphone
Phone won't charge
No you cannot use a motorola charger to charge an htc touch.
Aug 22, 2008 | HTC Touch P3450 Smartphone
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
