Question about Bosch Washing Machines
Bosch WFL 2050 won't spin
Machine is on but will not spin
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
  • 163 Answers
SOURCE: Bosch WFL 1300. The machine does not finish the
pump could be clogged or bad,or door switch is bad.any codes?
Posted on Mar 06, 2009
  • 16 Answers
SOURCE: Bosch Axxis WFL 2060 won't
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Posted on Mar 05, 2011
Testimonial: "Very fast response and provided 2 proposed solutions, so I'm pleased with the result. Got my machine whirring away-for free!"
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
Jul 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer wfl 2050/ 2060 door is locked and will not open
Tom
Unplug it from the power source.
It should release it if not you have a sticky selenoid that locks your system.
If freed. great.. but you need to have that selnoid replaced, because it will happened again.
If the power interruption doesn't work, you need to dismantle your system.
If still under warrenty... Cal a service guy
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
The drum won,t go around or spin BOSCH Classixx 1200 washing machine
BOSH WFL 2260 SPINS OK BUT WASHING CYCLES DO NOT WORK. FILLS WATER OK
Sep 26, 2008 | Bosch Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
