Question about Light Boating
Shifting into gear 150 johnson v-6 1995 adjustment
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
2 Suggested Answers
oldmanewtoys
  • 414 Answers
SOURCE: how to seaperate gear case from lower unit on 1987
four bolts on lower case. must turn shifter rod to the side to pull down case
Posted on Mar 05, 2010
150 johnson which of the cables are shift and throttle is top the shift or bottom?
Bottom cable is the shift cable.. top is throttle.. They should not work if hooked up wrong....
Jun 14, 2017 | Cars & Trucks
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
Changing impeller on 90hp v4 johnson 2000
Remove Linkage Under Carburetor
Remove Bolts Securing Gear Box Remove Gear Box
Do Not Turn Shift Linkage
Remove Water Pump Housing
Fit New Impeller
Re Fit Gearbox Follow Procedure In Reverse
Mar 16, 2013 | Boating
Gears stuck in 1st...on my ford 91 econoline 150 why also it started after I change the flywheel
When you say it is stuck in first, does that mean you can not shift into reverse or park, or that it won't shift higher than first ?
Is it possible the shift linkage is out of adjustment ?
Dec 14, 2012 | Cars & Trucks
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
I own a 1986 Dodge D-150 w/ and automatic transmission and when I shift the needle doesn't line up with the correct gear. I've tried adjusting the needle but it still won't line up.
mine is the same way but its on your steering colum were there is little slots on a thin metal strip for slecting your gears adjust with that
Apr 05, 2010 | 1986 Dodge D150
Shifter jumps out of forward gear on 64 9 1/2 hp Johnson motor
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
Jul 03, 2009 | Boating
We have very little reverse any thing above idle the prop just seams to slip 76 johnson 85 hp outboard thanks Ben
There are two things to look for. With the motor off disconnect the shift cable. Pull the boots off the plugs so the engine can't kick back. Grab the shift lever directly on the motor and pull it in the direction reverse is. Turn the prop and you should be able to feel reverse click in. If you just barely feel it "tick" the gears, the shift rod inside the housing is not adjusted. If the reverse "bites" into place as good as forward then leave it is that position. Next, line up the shift cable but DO NOT connect the end with the shift lever. Put the cable in reverse and you will see a gap from the old setting to the where it has to be to work correctly. Then its as simply as adjusting the shift cable to match the lever.
The second possibility is the rubber hub in the prop. It could be slipping. But usually its gone in both directions when this part breaks.
Jun 27, 2009 | Boating
1990 f150 transmission up shift to early
Sounds like the passing gear cable is out of adjustment. Get a shop manual and see what the specs are on how to adjust it properly. It is a pretty simple fix.
May 27, 2009 | 1990 Ford F150
Boating Logo
96 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
