Question about Nordic Track Audiostrider 800 Resistance 236670 For Model Number 236670
My NordicTrack audio rider r400 keeps saying check sum failed what could this mean
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: nordictrack audiorider r400 checksum fail
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Finally tight the flexible cord form keypanel vs display board and then tight the display board vs lower board.
See if you can meassure +5VDC from lower board to display board.
see the block diagram for your final diagnostic.
12_19_2011_5_43_08_pm.gifSincerely. Merry Christmas.
Ernesto cuadra
managua,nicaragua. c.a.
Posted on Dec 19, 2011
What is the sum of the first two multiples of 6?
Sum means product, as you say an addition of two multiples. The multiples are 1, 2, 3 and 6.
Mar 19, 2014 | Computers & Internet
The console not powering up
please see if your c.breaker is o.k 2) adjust the REED switch, clean it and tight the connector.see the diagram attached. 3) clean the ribbon cable inside the display board and tight 4) see if the power is coming to the display board.5) test the fuse.
Nov 14, 2013 | Nordic Track Nordictrack Audio Rider U 300...
Remove drive belt nordic track audiorider r400
see the video and follow the steps with common sense. God bless you
Nov 13, 2012 | Exercise & Fitness
Flashing Nordictrack R400 AudioRider Display
https://support.nordictrack.com/exercise-bike-support/
Apr 05, 2017 | Nordic Track NordicTrack GX 5.0 Pro...
Nordictrack audiorider r400 checksum fail
Ernesto cuadra
Dec 19, 2011 | Nordic Track Exercise & Fitness
I have philips dvd player with USB and iam getting an error " check sum fail" so what should i do for that ?
Issue with your laser Rider Check for dust on the length ..Use clean Q-Tips with a bit water on the tip ov our Q-tips dont use anyting else...
Sep 22, 2010 | Philips Televison & Video
Microsoft excel
this is done through formulas. You write them in relationship to one another. Say you put a value into B1 then you write a formula for c2 like =SUM(A1/2)which means the sum of A1 divided by 2. or you can say make a formula that is like this =SUM(A1/C1) which means the value of A1 divided by the value of C1.
Jan 10, 2009 | Computers & Internet
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Nordic Track Audiostrider 800 Resistance 236670 For Model Number 236670 Logo
15 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
