Question about Toshiba Satellite L555-S7916 Notebook
Toshiba L555-S7916 bios update - Toshiba Satellite L555-S7916 Notebook
How do i get links in emails to open
You need to click on enable links and pictures in the email
Oct 13, 2014 | Toshiba Satellite L555-S7916 Notebook
Toshiba laptop wont start up
check the fuse in the main plug.
get the power supply checked.
are you getting any lights on this laptop?
May 27, 2014 | Toshiba Satellite L555-S7916 Notebook
Hot keys not working
You will usually need to hold down a function key for your hotkeys to work, look for a key near the space bar that says "fn" or something similar
Apr 27, 2013 | Toshiba Satellite L555-S7916 Notebook
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
I need some adjecitves
I need some clever adjectives. Clever being the adjective.
Oct 01, 2012 | Toshiba Satellite L555-S7916 Notebook
L555-s7001 usb ports not working
It appears you have a Vista operating system on your Toshiba laptop.
Click on "Control Panel", on the next screen, click on "Device Manager".
That will open a window with a list of all the hardware in your computer.
Open the very bottom device which will be the USB's
Make sure that there are no "Question" (?) marks in from of the USB's devices.
If so then it may be that your "Chipset" for your model is not installed
or may be missing or corrupted.
Please go to the link below at Toshiba's support site, that page will have
the "chipset" needed on a list to be downloaded and installed, please follow the prompts.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2350413&rpn=PSLN0U&modelFilter=L555-S7916&selCategory=2756709&selFamily=1073768663
Good Luck
Aug 27, 2011 | Toshiba Satellite L555-S7916 Notebook
When my toshiba l555 battery runs low, I can plug in the charger but it will not charge unless I close it and put it in sleep mode. The battery icon in the lower right hand corner will read "plugged...
This is a problem I recently went through also, on my Dell Inspirion 1420. What you should do is replace the battery of the laptop, that fixed it for me. Laptop batteries are easy to find and replace, and you almost never have to open up a laptop to replace the battery. Generally you can find the battery on the bottom of the laptop, near the part where the monitor meets the main body of the laptop. Unfortunately, laptop batteries aren't very cheap, usually $50-$100, but I quick searched a replacement battery and found one for $35 for the Toshiba L555 series here, pretty hard to beat, and from a trusted seller too.
Apr 05, 2011 | Toshiba Satellite L555-S7916 Notebook
Hello
post ur problems on it
Dec 29, 2010 | Toshiba Satellite L555-S7916 Notebook
Fn/F8 did not show up in the options
It doesn't.  Just keep hitting F8 when it boots, just after the motherboard splash screen.
Mar 03, 2010 | Toshiba Satellite L555-S7916 Notebook
Toshiba Satellite L555-S7916 Notebook Logo
11 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
