Question about Azza Gaming Keyboard
Azza mouse not working - Azza Gaming Keyboard
The headphone jack on top doesnt seem to work and i dont know what the button on top by the left is for- I have the azza 1000
Usually if a jack doesn't work, it's because it isn't plugged into the motherboard correctly, or you have it muted in Windows. Check both things, and if it still isn't working, then possibly you have a bad jack, or bad plug onto the motherboard. Here is the manual, in case you didn't have yours. http://azzatek.com/Manual/CSAZ-1000Solano-manual.jpg
Jun 03, 2011 | Azza Solano 1000R Black ATX Full Tower...
How do you use/connect the blue USB 3 cable in the AZZA Hurrican 2000 case? Does it require a motherboard with a USB 3 connection? Or does it require a USB 3 PCI card? Right now it is just dangling into...
You need a usb header for it on your main board or you need an external usb 3 cable to run it to a usb 3 port at the back of your box.
What I'm not quite understanding is why you have the blue cable as well as a normal usb connector dangling from the end of it. When I connected both of those up to usb3 ports I shorted out my motherboard. Not good.
Also I'm not entirely sure that the blue cable works for me. I couldn't read my external flash drive with it.
Jan 09, 2011 | Azza Full Tower Computer Case with 4xEasy...
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
Drivers
Driver can be found here
If it was helpful rate Fixya
Oct 12, 2008 | Azza 845G-MLT Intel 845G mATX Motherboard...
Motherboard drivers
pls..i need a motherboard driver M7VIQ Ver.1.3 my software is lost...pls..
Sep 26, 2008 | Computers & Internet
P4X4-ALH MOTHERBOARD
You can download the manual from here:
http://www.elhvb.com/mobokive/Archive/Azza/manual/UM-P4X4-ALH-E1(3).pdf
2cf8a34.jpg 91b9251.jpg PW= Power On/Off and Suspend Switch Connector
SL = Sleep LED Connector
HL = HDD LED Connector
RS = Reset Button Connector
Did this help calgary12?
Mike
Aug 04, 2008 | Azza 845G-MLT Intel 845G mATX Motherboard...
Old Azza mother board drivers???????
Try a program called Driver Detective. It's not free but it will work. Like you I couldn't find a thing. Lots of luck.
Nov 24, 2007 | Intel Motherboard
Azza Gaming Keyboard Logo
59 people viewed this question
Top Azza Computers & Internet Experts
David Payne
David Payne
Are you an Azza Computer and Internet Expert? Answer questions, earn points and help others
