Question about HP Office Equipment & Supplies
Printer hp deskjet1513 all in one
I have a printer Printer hp deskjet1513 all in one, which amber light is just blinking, i have tried to change the toner cartridges but still here is no change. please assist.
    Problem Solver:
  • 8 Answers
Use this link for the User Guide
http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
The print-carriage access / front cleanout
door is open, the print cartridges are
missing or not installed properly, the
protective tape is still on a print
cartridge, or a print cartridge is defective
Posted on Jun 18, 2009
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
My printer had the toner light flashing I replaced the cartridge with a new one but the light is still flashing. What do I look for now?
did you replace orginal HP cartridge? if you are change refill or any other kind of manufature cartridge , there is chip is not working properly, that's why ligh is blinking, use orginal HP toner or good quality brand
Dec 01, 2010 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Hp deskjet 1513 all in one
Great you changed the toner cartridges but you may also need to do the following as well.
Imaging drum is low Light pattern c00189128.jpg Description The imaging-drum light is on. The printer continues to print without any action required until the imaging drum is empty. Action Order a new imaging drum. Have a good day
Jun 18, 2009 | HP Office Equipment & Supplies
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Sep 08, 2008 | HP LaserJet P2015dn Printer
Canon Bubble Jet iP1600
Hi meemee, If ink comes out of the ink nozzles on the cartridge then you probably just need to reset the printer page counter. Each time the cartridge is removed from the printer an empty cartridge message appears and a blinking amber light will display on the printer. Hold the paper feed button down for 3-5 seconds, and that should override the counter. If ink isn?t coming out of the ink nozzles then you may have an air pocket preventing the flow of ink. Try running your printer cleaning cycle a couple of times to see if that helps. Lastly you might try letting the cartridge site for 24 hours to let gravity try to fix it. As a last resort you can try unplugging your refill hole in the cartridge. If your cartridge ink is going to flow it will now, just be ready to re-plug the fill hole. Let us know how it goes and don?t forget to rate the post.
Jan 03, 2007 | HP DeskJet 3325 InkJet Printer
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
