Question about Vacuums
How to Replace belt on Hoover Turbo power 1500 vacuum
reddevil6
  • 1673 Answers
SOURCE: Replace the belt
Take off the bottom plate, put the new belt on the motor shaft first, then stretch it to go over the pulley, it is hard, but it will stretch to go over it.
Posted on Mar 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt Replacement
Take the bottom plate off, the brush roll and belt are there. the belt goes around the brush roll and hooks to the motor shaft. If you can't get to the motor shaft, then you will nee to remove the top cover also.
Posted on May 13, 2008
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
VacuumRepair
  • 438 Answers
SOURCE: Replace belt for Hoover Windtunnel Turbo Power
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Posted on Mar 21, 2010
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!) http://www.elkypro.com/hoops2005/vacuum_parts/hoover/U5461-900.html
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Posted on Apr 29, 2010
How do I put on belt? cleaning lady took old one off so I'm lost. It's a hoover turbo 3000.
Assuming this is an upright vacuum, the belt is located under the bottom case and runs between the motor drive pin and round the brush or beater bar. After removing the screws to expose both of these pull up on bar, wrap belt around moter drive, replace idle side of bar, insert bar into belt and stretch to drop into place.
Mar 23, 2015 | Hoover Vacuums
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
Vacuun does not get up dirt into vacuun
check all hoses ect for blockages ... see if belt has snapped on roller ...replace if need too. also check filters give them a clen.
Feb 25, 2011 | Hoover Windtunnel Turbo Power U5761-900...
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
My girlfriend has a Hoover upright vacuum, Mdl. # U4645-930. I need a belt for the brush and a new bulb and am having trouble finding the correct part numbers so I can pick one up locally. Can you help?
I checked with Hoover and they said the part number for the belt is #38528040, for the bulb #27313101, and they also included a part number for something called an agitator #48414081. Not sure if this is required to replace one of the other parts. You might ask when ordering. To order, call 1-330-499-9499 or online at www.Hoover.com.
Dec 16, 2008 | Hoover Windtunnel Turbo Power U4645-930...
How to change belt on hoover turbo 4600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=841267
Generic problem for all Vacuums
Posted by tbellme on July 27, 2008
How to change belt on Hoover Turbo 4600
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
Changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Dec 31, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self Propelled Wind Tunnel Turbo Powered 7600 The thin belt too loose
If this is a "V" belt, make sure the small roller that tightens the belt is ok and not jammed up. It may have to be replaced. Also if the flat belt is stretched at all, it won't work either.
Nov 18, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
