Question about Axion AXN-8701 7 in. Portable TV
Universal remote code original - Axion AXN-8701 7 in. Portable TV
The remote only controls the volume, not the channels, etc.
Laura, If it is a universal remote you will have to reprogram to your TV with the correct code. If it is your original remote change the batteries, if original does not work after new batteries, replace it.
I will post links to how and set up universal remote and codes.
How to Program Universal Remote
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
http://www.remotecodelist.com/
Mar 24, 2016 | Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Code for universal remote
There is no true 'universal' remote since new code sets are being created all the time and a remote that was designed two years ago cannot contain newly created codes.
Before buying a remote, it's wise to go to the maker's site to see if it will do the job you want.
If an original remote has died, and you don't want to toss whatever electronics for which it was made, go to the linked site below; they offer the broadest line of real originals or tested 'universal' substitutes.
Not cheap but great inventory:
1 800 Remotes Factory original replacement remote controls
Jul 05, 2015 | Universal Televison & Video
I have telefunken Vegas 127cm plasma tv model no: VPM-500FHD. Can someone help me with a "one for all 4" universal remote code? Pretty pretty please.
You might check at the link below for a code but nearly all 'universal' remotes really aren't universal.
Before replacing a failed original remote, get makes and model numbers of those you have seen, then check on line for the code tables to avoid buying one that will not work with your gear.
Jan 09, 2015 | Universal Televison & Video
Universal Remote Control code for neonIQ LCF3218
I am guessing you have a universal remote to replace the original NeonIQ remote. If so, you can use the universal's "code search" feature to find a code that will work. Codes are stored in the remote. If a thorough search does not turn up a usable code, you may have to try another universal remote. Not all codes are stored in every universal remote.
Sep 17, 2014 | Televison & Video
Sony trinitron number is kv20fv12 what is the number for a remote controller for this tv
The original remote control number to this set is {RM - Y198}. If you buy its original one, contact the nearest authorized service center for Sony. The universal remote control codes for Sony Brand Tvs are: 0128 0013 0002 0071 0380
If you wish to buy a universal remote control, check whether there is these codes with its code list. The code list will be attached with every universal remote control pack. Make sure there are these codes with it.
In my opinion, it will be best to buy its original one. Original is Original, and Universal is Universal!!
Oct 27, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Polaroid remote tdac-02212 code?
If you are using a universal do not expect it to even if it programs to have all the functions you need or want or had with the original remote.
Universal remotes are far from UNIVERSAL.
The best argument for an original remote is even if it programs it will just not have all the features needed or wanted that the original had.
Hope this clears things up a little.
Apr 03, 2012 | Polaroid 1720-7 Remote Control
WILL UNIVERSAL REMOTE FOR PANASONIC DVD/VCR ENABLE ME TO USE MY OMNIVISION PANASONIC
Yes,if the universal remote have codes for panasonic models that work for panasonics devices.But universal remotes devices are have very limited functions,not like the devices original remotes.Try website like Remotes.com to buy the devices original devices remotes,best in the long run.Like never worries about models codes again ever,if the universal devices for long period times,will require enter universal codes again.If u buy a universal devices,must keep universal manual book safe all the times ok.
Jul 02, 2011 | Televison & Video
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Axion AXN-8701 7 in. Portable TV Logo
44 people viewed this question
Top Axion Televison & Video Experts
Steve
NOEL
NOEL
richie46
Are you an Axion Televison and Video Expert? Answer questions, earn points and help others
