Question about Coffee Makers & Espresso Machines
Hi... i have a gaggia syncrony coffee maker.. i am just descaling it... but dont seem to be gettin any hot water... any ideas? thanks
  • garykittaylo Jun 18, 2009
    Hi thanks... the coil...? is this the heating element?? where can i find it? thanks
    would the machine show the message warming up.... if the heating coil were damaged??
    President:
  • 1,383 Answers
You have to check coil is proper working or not?
Coil is main part to heat water.
Check its working condition and laso chek that it gets enough power.
Posted on Jun 18, 2009
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
My Gaggia syncrony digital has just stopped working....the coffeee is still being ground but there is no coffeee coming out....no water seems to be getting through. Any ideas?
There is one of 2 things going on either the machine needs to be descaled and or the brew unit screen is blocked. Remove the brew unit from machine and check screen below the red o-ring.
Aug 04, 2011 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact.No coffee comes out. Coffee grinds then the 3 big clicks, then nothing comes out - grounds get dumped. Bought a new brew group, but same problem.Looked at the book and tried to...
Your machine have scale deposits in a very hard form that is why the water can not run freely.
Here in this link you try descale
http://www.fixya.com/support/r4335301-descaling_espresso_machines_never_use
Try it for 3-4 days repeated, if you dont have any results then you need to desmndle the machine and manualy descale it.
Sep 24, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
Syncrony digital gaggia coffee maker leakage+ventilate message
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
I have an old larger version of the Digital Synchrony and have a message that says 'hot water ventilate'. I have tried to run hot water through the machine using the hot water tap/button but nothing...
Check the end of the steam spout that may be blocked, use a paperclip to clear. If you still get the same result then the machine needs to be descaled.
Oct 08, 2009 | Gaggia Syncrony Compact Coffee...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
