Question about Sunbeam Food Mixers
Mixmaster mx8800 How do I remove the motor and gearbox assembly from a mx8800 mixer housing so I can repair the gearbox,child put a spoon between the beaters and the machine has know seized,is there YouTube vid about this
night71
  • 328 Answers
SOURCE: Disassembling the gearbox on Kenwood mixer A707
If the belt wheel is pressed onto a spindle, you need a gear puller. Do you have any pictures of this? I am trying to visualize the problem.
Posted on Nov 10, 2007
SOURCE: bravetta mixer
Call Euro-Pro Operating LLC at (800) 798-7398
Posted on Dec 04, 2007
SOURCE: Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Posted on Oct 22, 2008
Loringh
  • 185 Answers
SOURCE: Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Posted on Nov 09, 2008
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
Worn out beater gears
Soft plastic gears inside the machine from what I've read around the web, sorry but you'll need a complete new mixer.
I've had one apart to see just how fixable it might be, and it took me about 30 minutes to get the motor and gearbox into a position where they could be looked at. The gearbox had 2 stainless steel clips holding the top cover on and I didn't want to pry at those in case the cover snapped.
Not a lot gained from looking inside it sadly.
Apr 12, 2013 | Sunbeam 2346 Heritage MixMaster Series...
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
I have the Sunbeam portable mixer 2486. I was making Parker house rolls with the dough hooks. After blending the dough, the mixer just stopped. The motor will no longer be turned on or off. I want to...
Hi Janis.
You have likely burnt the motor. That is the most common fault when the mixer is used for a prolonged time on a compact dough.
The best thing to do is ringing Sunbeam at the number listed on the owners manual, and checking what conditions for repair are offered.
If you have misplaced the manual, then track the number using Sunbeam website: Sunbeam.
Regards.
Mar 02, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
Wooden spoon killed the motor!
these mixers use an electronic triac(to vary the speed of the mixer) of such low amperage that they run hot normally(to wear OUT), and they don't fuse the units electronics or motor anymore so anything that binds them will short out the triac or motor winding(from heat) and make them inoperable,try and order(what they call) an internal electronic part from these companies and good luck, I tried for 3 months and told them what I needed,they agreed this part was defective, but they wont sell you an internal part(LIABILITY ISSUE) unless your a "company certified technician" go figure, I finally got one through N.T.E.semi-conductors. and my customers HAPPY NOW!!!
Oct 06, 2009 | Sunbeam 2366 MixMaster Series Hand/Stand...
Need to replace cord on vintage Sunbeam Mixmaster Junior
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
Mar 10, 2009 | Sunbeam Food Mixers
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
I have an old sunbeam mixmaster that trips the safety switch
Zaczac,
There are two probable causes for this. One is that the insulation in the motor has broken down. This is definitely an unsafe condition, and unless you are a motor repair specialist there is nothing you can do.
The other cause is an accumulation of graphite around the brush holders. Fixing this would require pulling down the motor and cleaning the graphite away. This usually happens with motors that have done a lot of work.
It is normal that by the time the brushes have worn so much that the dust causes shorting the motor needs to be serviced.
Read this to understand what is required to pull the motor down and to reset the speed control:
http://www.fixya.com/support/t2208012-sunbeam_mixmaster_12_speed_may_need
Just cleaning the motor housing out thoroughly may get the machine running. I make no guarantees though. If the motor insulation is failing the motor will remain unsafe.
Apr 24, 2008 | Sunbeam 275 Watts 2369 MixMaster Series...
Food Mixers Logo
93 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
