Question about LG WT5001CW Washer
Wt5001cw drum not spinning
Bottom portion of the drum is rubbing on something underneath
Lg waveforce washer grinding sound
If it is just coins, I wouldn't bother. However, depending on the age and or unexpired warranty, I wouldn't jeopardise the warranty.
It could be the agitator's transmission, which if it is under warranty
should be fixed by the MFG. If out of warranty, unless you are a DIY, you need to call appliance service people. Ask the approximate price for repair. Depending on the age, it may be time to look for a lightly used replacement.
Mar 17, 2013 | LG WT5001CW 27" Top Load Washer with 5.2...
LG wm2016cw smells when spinning fast. I opened the top but do not visually see any damage or smell it. When I open the door, I can smell something was rubbing. Took off the door gasket and it seems fine....
It sounds as though the drum may have dropped slightly and is rubbing against the seal. This normally occurs when either the top springs have stretched slightly (visually it's not noticeable) or the bearings are worn. Hopefully it's the former, as the springs are replaceable at little cost and can be done as a DIY project. The best way to see if it is the drum, is to close the door and look through the door window. The drum should appear central to the window. There will be online guides on how to change your particular model springs, as they are all slightly different. The only other possibility is that the drive belt at the rear of the machine is wearing out, or rubbing against something.
Dec 04, 2017 | Washing Machines
Hello. Near the end of the spin dry cycle, the drum started to make a loud rubbing sound (12 minutes to go???). We shut down the washer, with a cancel, then restarted the load over again. This time we...
100% if its rubbing instead of freely rotating while you manually spin the drum your bearings have gone,You can't see it's all inclosed in a plastic shell & it is pretty much a complete rebuild pain in the neck job that you are going to recieve quote's of $500 buck's or more to do the job might be worth getting a new machine it would be more economical.GOOD LUCK
Feb 25, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Scrapping sound
likely something else like bra wire sticking up from drain hose rubbing basket. remove front kick panel or rear panel and remove large hose from bottom of tub. clip usually positioned in rear. if unit with heater then heater and clip can be felt inside tub. check inside hose
Apr 26, 2009 | Kenmore HE2 Plus Front Load Washer
Dryers drum is not spining
I was having a similar problem but my dryer was about 5 years old. There are a couple of rubbery, sticky belts that wrap around the dryer drum. One of mine had come off the drum and was balled up, wedged between the drum and the dryer wall. It wanted to spin, but this "belt" was keeping it from doing so. I'm not sure why or how it happened, but I removed the portion that was gummed up and now it works fine.
Nov 25, 2008 | GE Profile Harmony DPGT750EC Electric...
Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Jun 02, 2008 | Maytag Atlantis MAV6451 Top Load Washer
LG WT5001CW Washer Logo
49 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
