Question about Electrolux Guardian Bagged Canister Vacuum
Lux guardian has power to the nozzle but the motor in the canister quit after we changed the bag
  • 15 Answers
SOURCE: I have an electrolux canister 5000 lux - power nozzle not working
HAVE YOU TRIED PUSHING THE RED "RESET" BUTTON?
Posted on Dec 02, 2007
  • 15 Answers
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
Posted on Apr 10, 2008
  • 13 Answers
SOURCE: How to replace the elboe on the power nozzle
wouldnt recommenddoing it urself as it may have warranty. But if u have the head off and the elbow apart im not sure what parts u have. If u have both these taken apart. It is pretty much self explanitory. u need to take the prongs out of the one end. At the other end ot the wires there r two attachements. The end that is at an angle attaches to the reset button which is by the L shaped part. The opther wire attaches either directly to the small motor itself, or to another wire which has a plastic cover on it. The wires that you took the prongs off of the rest along side the little knobby piece and then you wrap them around the middle of the knobby piece. Slide the elbow sleeve over the knobby piece and then turn it so u can bring the ends of the wires out of the little hole in the middle of the elbow sleeve. When the is done attach the two little clips back on the the elbow the one on the inside and the one on the outside at the back of the elbow. reattach the prongs to the ends of the wires put them into the notches about the middle of the elbow sleeve. Reattach the little cover and ur done. If u have the whole assembly. Take p/n cover apart and reattach wires where they r already connected inside the head. Put the head back together. Feel free to give me a call 1-866-966-9350.
Posted on Oct 02, 2008
  • 70 Answers
SOURCE: Electrolux Lux 5500 model Canister vacuum. Need
The part # is 32749.
Posted on Jul 15, 2009
  • 70 Answers
SOURCE: just bought new power head electrolux guardian and
Did you get new wands with the power nozzel? The wires that power the nozzel run through the wands from the hose to the nozzel.The connectors at the end of the wires are fomous for getting too big and making a bad connection. This causes the on/off problem. This will only get worse if you continued use. The wires in the hose handle, the hose and the power nozzel elbow can all be changed out. You will not have to replace the hose handle or the wands unless the plactic has been burned. (A loose electrical connection causes heat). Take your hose,wands and nozzel to the shop for repair. Don't let the sales/service manager tell you that you need new parts until you can see the parts are bad. I think they saw you comming when they sold you the new nozzel.(just my opinion)
Posted on Oct 18, 2009
Where is the reset button on my electrolux guardian canister
There is a reset button on the power nozzle...not sure I heard of the vacuum canister has a reset button....hum.
Feb 15, 2013 | Electrolux Guardian Bagged Canister Vacuum
I cannoot find bags to fit my Little Lux Model # L673BA
You can find those bags at
http://www.totalvac.com/850-12.html
Fits all Electrolux canisters/tanks made after 1954, (except Lux 9000, Guardian, Epic 8000, Renaissance, Harmony or Oxygen models) Generic 12 pack of Electrolux vacuum bags.
Mar 01, 2011 | Electrolux Little Lux Bagged Handheld...
Power nozzle N106M on our Electrolux Guardian has stopped workin
Start simplest always and work back to most difficult... so make sure you have power to the main unit, do you have a cheap voltmeter? If not they're cheap... Second check that connection plug is not stuffed with debris. Point is isolate whether it is the unit or attachment, most likely it's in the connection and repairable by you or used vacuum repair.
Aug 04, 2017 | Electrolux Guardian Bagged Canister Vacuum
Lux legacy canister vacuum - the top light on the canister went on. No power to the bottom of the roller. What does that light mean. Looks like a plug
The "plug" light simply tells you the machine is plugged in and receiving power.
I'm not sure what you mean by "no power to the bottom of the roller". If the power nozzle motor isn't working, make sure nothing is wrapped around the brush, remove if there is, and press the reset switch.
If the power nozzle motor is running, but the brush isn't turning, then the belt must have broken, and needs to be replaced.
Considering your machine may still be under warranty, I suggest taking it to a local Aerus dealer and having it replaced.
You can find the store nearest you using the below site:
http://www.aerushome.com/shop/
Apr 27, 2010 | Electrolux Guardian Bagged Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
May 11, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
35 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
