Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi magniica eam3400 won't rinse or deliver coffee
Rinse water and coffee is coming from behind the door. Machine has been thoroughly cleaned.
4 Suggested Answers
SOURCE: Delonghi EAM3400 water ends up in tray will not come out of spout
i had this problem, and have now finally figured it out and fixed it. the problem is that there is a solenoid valve sticking. i believe that the valve is used to relieve pressure after using the steam, and it vents the hot water directly to the tray. if you aren't diligent about descaling, or if there are water impurities, or if you use the machine infrequently, or for probably any number of other reasons, the valve can gum up and stick in the "open" position, continuously draining the water directly to the tray.
one easy way i've got my machine to work was to cycle steam on and off a few times, thereby signaling the valve to open/close, and unsticking the valve. you can see if it worked without wasting coffee by initiating a rinse cycle, and seeing if the water correctly comes out of the coffee nozzles.
if that doesn't work, you can disassemble the machine and tap on the valve. it has a square black solenoid ~1" square on top of a brass valve. it is mounted on the same bracket as the u-shaped heater. a few sharp raps on top may free up the valve.
if that doesn't work, remove the valve, and try to blow through it. if the valve is stuck open, air will go right through. hold the valve upright and tap it onto a hard surface (countertop, floor, etc.) try blowing through it again. when the valve is unstuck (and held in its normal operating position), you will not be able to blow through it.
once the valve is unstuck, run your machine through a descale process. that should take care of it.
Posted on Feb 13, 2010
  • 1089 Answers
SOURCE: I have a Gaggia Titanium. It has stooped making
If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head.
If it run normally, your grind is to fine. Turn the grinder knob to a larger number. It takes 3 times to change to the new grind.
If it still dribbles, remove the brew unit (behind the door)
Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the front side towards the door. 2 screws hold it to the top. Remove the 2 screws while holding the manifold. Once they are removed, lift the l assembly off (becareful, there is a spring and inside a steel ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the steel ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out.
Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers.....
Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side.
Now use air to blow back through the opening where the steel ball was to clear the opening. Once its open, clean then reassemble. Brew unit on towel right side up. Drop the steel ball in first. Then the spring.
Then place the manifold on top of that with the pipe towards the door. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head.
Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Posted on Jan 02, 2011
mnwarfield10
  • 452 Answers
SOURCE: The machine is making strange noises when grinding
when first started up turn the steam valve open to get out air ... job done i hope or you need it repaired ... bsc appliances 07779933829 we repair via postal service anywere .
Posted on Feb 27, 2011
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Delongi magnifica EAM3400.n leaking water and coffee not flowing to cup
Hi i would start cleaning the machine with the cleaning stuff that is recommended. By the way from Electrolux comes a very good cleaningstuff.
Sep 17, 2013 | DeLonghi Magnifica Coffee Makers &...
I own a Delonghi EAM3400 Expresso Machine that has stopped processing water through either the steamer or spout where coffee is dispensed. The unit is ~5 years old and is used 2-3x's daily. There appears...
turn unit on ...switch on ... turn water steam control to open position ,,,,,it should sound load then go quite as air lock will come through .. hope this works if not i repair you need spares .. ..postal service too 07779933829
Feb 23, 2011 | DeLonghi EAM3400 Espresso Machine
Delonghi Magnifica door comes open after grind and just before brew?
try changing the defusser..... bsc appliances 07779933829 postal service too.
Feb 07, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Jul 20, 2010 | DeLonghi EAM3400 Espresso Machine
Leaking water when not in use
With your DeLonghi off, open the front door and remove the diffusor. You will then see two hex socket screws holding the backplane that holds the diffusor. Make sure that these two screws haven't worked loose; it's a simple job to tighten them if they have. Then re-install your cleaned-up diffusor, and see if that solves the problem.
Jun 23, 2010 | DeLonghi EAM3400 Espresso Machine
Jul 22, 2009 | DeLonghi EAM3400 Espresso Machine
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
