Question about Dewalt Garden
Dewalt 3400 with Honda motor has two oil fill holes?
What type I need gearbox oil and how many liter I need pls advise
is this a manual or automatic. manual trans take 80/90 weight gear oil and you fill it to the bottom of the fill hole. the amount depends on if your topping it up or changing all the oil. most take about 4 litres. at any rate fill to bottom of fill hole. if automatic you can use Dexron trans fluid or Honda trans fluid. fill until the level is within the add and full marks on the dip stick.
Jul 15, 2015 | Honda Fit Cars & Trucks
How do you replace DeWALT D55154 electric motor brushes?
That model does not have brushes. You can see the parts diagram with this link.
Detail
May 25, 2014 | Dewalt D55154 Heavy-Duty Continuous 4...
What oil weight is used in the pressure washer pressure unit
Non-detergent 20-30-weight goes into pump port, and is filled about half way.
Ordinary motor oil 10-W30 or 40 goes into engine port.
Nov 11, 2012 | Dewalt Gas Pressure Washer: 4200 psi 4.0...
What oil to use
Your manual will say to use General pump oil GP100..or whatever DeWalt's number for that may be. See dewalt.com for their proper part number. From the pictures of that model I see on line, that is a General Pump and they have recommended Non-detergent 30w standard motor oil in the past. We like to use a non-foaming full synthetic 20-50w racing oil on these high RPM pumps.
Oct 20, 2012 | Dewalt DXPW4240 4200 PSI Direct Drive...
Have 10000 miles on my bike does the shaft drive oil need to be changed or what?
Final drive assemblies on motorcycles generally cost over $1000. They tend to show signs of dirt after only 5000 miles. Having driven shaft drive motor cycles for over 30 years I usually change my 85/90 Hypoid gear oil at every second engine oil change. It is never very dirty but if taken into the sun light will show some fine metal chips (nothing to worry about). I highly recommend using synthetic Hypoid gear oil. It will cause less friction and the final drive will run at a much cooler temperature. One quart of Hypoid gear oil will change the rear end oil 3 or 4 times so it is good, cheap preventive maintenance. Simply take off the large fill cap, place a pan under the small drain bolt at the bottom of the pan,remove the drain bolt, drain the oil, put the drain bolt back in, and fill the final drive to the bottom of the larger fill hole (usually a quarter to half cup of oil), then replace the large cap being careful to only snug it tight enough to seal in the oil. If you over tighten it, it is designed to break! Be sure to check the owners manual on the exact amount of oil to use. Honda has changed the fill technique for some of the newer models. With a higher fill hole on some newer models you may be over filling the final drive, so you may have to measure the amount. Too much oil will cause waste and may cause over flow out the top vent. Happy Trails.
Aug 15, 2011 | 2004 Honda VT 750 Shadow Aero
How much oil what wt.
Most any kind of 4-cycle motor oil like 10W-30 will work in these motors. After draining the old oil replace the drain plug. There are two types of motor oil fill holes: 1. If you have a motor with the oil fill/check hole on the bottom of the motor and a small screw-in plug either with or without a small dip stick on it; with the motor level, fill the crank case with oil until it is up to the threads on the oil fill/check hole. 2. If you have a motor with a long dip stick that goes into a filler tube at the top of the motor, again with the motor level, put in about half a quart of oil and use the dip stick to check the oil level. If not full, add quarter quart amounts and check again until the oil is at the full mark on the dip stick. Do not overfill the crank case with oil. Most motors will take about one quart of oil but it varries so watch to see the oil level come up to the proper level.
Feb 03, 2011 | Porter Cable PorterCable DBSI325 3250 Watt...
Dewalt /Emglo 10 gal ,150 psi with 5.5 Honda GSX just shuts off sometimes ,some days it works fine ,some days it wouldnt work at all ,looks like something with gas ,it would shut off after pumpin tank...
I have an Emglo compressor with a 8 HP Honda motor. The motor has a low oil level shut-off switch in the crankcase. My switch failed intermittently and the motor would run sometimes and not others. There is a wire going directly into the motor crankcase. On my unit, the switch is normally open and when there is enough oil in the motor, it closes to allow the engine to run. If you can't start the motor, unplug the wire that goes into the engine from the connector. Then stick a wire into that connector and hold it to metal on the engine & try to start the motor. If that switch is the culprit, it should now start.
Be advised that running the motor without the switch in the circuit would allow the motor to be run with no oil in it.
Dec 06, 2010 | Dewalt Heavy - Duty 5.5HP, 10.5 Gal., Gas...
How much oil do I put in my Honda GX390 13hp Pressure Washer. Theres no lines on the Dipstick
you fill the oil up to the dipstick hole,just so it doesn't over flow out.
Nov 13, 2010 | Honda Garden
Dewalt compressor not filling with air
if you do not have any air leaks and it is a oil less compressor than it is most likely the piston seal is wore out. if it is an oil compressor that it is likely a flapper valve
Dec 05, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Garden Logo
65 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
