Question about Plumbing
Rotten egg smell - Plumbing
    Novelist:
    Champion:
  • 227 Answers
If the smell appears only when using hot water, then it is your anode causing the smell. Replace it with the non-smelly type. (I can't remember which maetal is the non-smelly one but your plumbing supply should know. If you have well watwer and the smell is present in both hot and cold water, then you have sulurous water. It won't hurt you but it does stink.If its a well, dump 2 gallons of chlorine bleach down the well head, let stand for 24 hours and then flush for 24 hours. You can also purchase a venturi and a conditioning tank. The venturi introduces air into the water entering the tank and an auto vent vents it out with the smell.Where ever the tank is will stink of sulfur, but your water will be good. You can also buy a tank and fill it with activated carbon. Expensive but effective.
Posted on Oct 28, 2014
3 Suggested Answers
  • 2692 Answers
SOURCE: rotten egg smell / sink
Two different problems. Rotten egg smell is sulfer from the water supply, especially strong in heated water. Drain may need to be cabled out.
Posted on Mar 12, 2009
  • 3287 Answers
SOURCE: smell of rotten eggs in shower drain
This is likely "sewer gas" and can cause headaches, dizziness, etc. if you remain exposed to it for a prolonged period of time. This originates mostly in the drain openings of fixtures that are seldom used - such as sinks and showers of basements, guest rooms, etc.
When these fixtures do not get used regularly, the relatively small amount of water that is designed to always be present in the "trap" portion of the drain pipe eventually evaporates. This trapped water prevents the the gasses in the sewer / septic system from passing through the trap. Without it, these gasses will rise through the pipes connected to the sewer / septic system and exit into your living space via the drain opening in the floor drain, shower, tub, sink and even toilet if left unused long enough.
It is usually resolved very easily by slowly pouring about a 1/2 gallon of water down the drain. The water now isolates the drain opening from the sewer / septic system and effectively stops odors from escaping. If you find that this is happening regularly (often from floor drains in dry basements) you should slowly pour water 1/2 gallon of water into the drain, and then add 2 to 3 ounces of cooking oil. The oil is lighter than water and will sit on top of the water surface. Oil does not evaporate and blocks the water from evaporating through it. Evaporation of the water in the trap will take place from the sewer / septic side of the trap, but it occurs at a much slower rate.
After filling the traps with water or water & oil, just ventilate and you're done!
Posted on Apr 05, 2014
My car has a rich gas smell then when it warms up smells like rotten eggs does it have something to do with the cadillac converter?
Maybe.
The rich gas smell is probably due to injector problems. The rotten egg smell is sulphur in the fuel, which reacts to the catalytic converter. The rich smell would need to be fixed first by checking the injectors and the engine computer.
Feb 16, 2015 | Cadillac Cars & Trucks
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
Truck is giving off a rotten egg smell !
rotting egg smell is associated with your cat converter going bad
Jun 24, 2013 | 2004 Cadillac SRX
Car runs ok, but gets hot and rotten egg smell comes out of the exhaust
If car runs okay with egg smell, its normal and working the way it should, if car is running poorly and the rotten egg smell has gotten worse, its a sign that your exhaust catalytic converter will need to be replaced. good luck!
Aug 12, 2011 | 2001 Oldsmobile Alero
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
Jun 05, 2011 | Pontiac Grand Prix Cars & Trucks
Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Mar 17, 2010 | Home
Engine light
The "rotten-egg" smell is caused indirectly by the catalytic converter. The main cause is a rich mixture condition from the engine. Your SUV is equipped with a computer controlled engine management system. You can scan your computer for fault or error codes. The information should pinpoint the malfunctioning components. There is an alternate reason for the rotten egg smell. this also can be caused by a over charged battery. if so, make sure the alternator isn't overcharging the battery cell. it will boil the contents causing the egg smell. I recommend a diagnostic run to make sure what this problem is.
please rate and god bless.
Mar 17, 2009 | 1999 Dodge Durango
Rotten egg smell / sink
Mar 12, 2009 | Plumbing
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Plumbing Logo
138 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
