Model Gateway DX 4860 UR28 Power button does not turn computer on somewhere there's a short on power module I was wondering if there is a reset switch or if there are any fuses that could possibly be changed?
fwadley
  • 482 Answers
SOURCE: power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Posted on Nov 27, 2007
SOURCE: Reset button or fuse
washer keep draining
Posted on Jan 13, 2008
SOURCE: power supply for gateway
This power supply has an odd form factor so just "any" power supply won't work.
Posted on Oct 03, 2008
SOURCE: Unable to turn on my labtop (gateway 7326GZ) computer.
I saw this part available really cheap from Computer Parts Outlet.com
Posted on Jan 27, 2009
Roop1980
  • 228 Answers
SOURCE: Printer won't turn on.
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Posted on May 03, 2009
How do i open bios on gateway dx4860-ur28
To enter the BIOS, press Esc on your keyboard (upper left) while booting. See page 36 in the downloadable manual here... http://www.manualslib.com/manual/253475/Gateway-Dx4822.html#product-DX4860
Jun 17, 2014 | Gateway DX4860-UR28 Desktop PC with 3rd...
Gateway dx 4300-11
probably your power button wore off, replace it with a new one
Mar 26, 2013 | Computers & Internet
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
I have a gateway 6520gz it wont power on i tried taking the battery out and draining the free power but the lights only turn on for just a second then nothing.
Hello Joalgd. hard to say this but looks like your laptop is done, it's a motherboard failure, it has a short somewhere and due to this short the laptop cannot power on.
Feb 10, 2011 | Gateway 6520GZ Notebook
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
Gateway dx 4820 power up problem
Let's start with some of the basics.
1) Since you were checking connections on the motherboard, was the power unplugged from the computer, AND did you follow Anti-Static precautions?
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit), the hardware components inside a computer.
You may not even see it, or feel it.
Computer unplugged from power, computer case open, computer on a table.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you get up in the middle of working on your computer, and leave, upon your return Touch the metal frame again.
Or use an ESD wrist strap, and connect the alligator clip to the metal frame ]
2) Computer unplugged from power, anti-static precautions followed, remove all ram memory modules, and reinsert them. In fact, it would behoove you to clean the contact pins on the bottom of the ram memory modules, before reinserting them.
Clean with a pencil eraser. Remove the eraser dust, with air pressure from a can of compressed air for computers, or air pressure from your mouth may be sufficient.
You may have bumped the ram memory modules.
Even if they look to be seated, it only takes a few minutes to remove, and reinstall.
After time, corrosion can develop on the gold plated contact pins, at the bottom of the ram memory modules. Doesn't take long to clean them with a pencil eraser.
Handle the ram memory module by the body. The body, is coated with a clear see-through protective plastic.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The above link, is only provided for an illustration of the gold plated contact pins, I am referring to.
It is DDR Sdram ram memory, and has 184 contact pins. 92 on each side.
Your computer uses DDR3 Sdram ram memory.
Has 240 contact pins. 120 on each side, and the Locating Notch is in a different place.
3) Are you sure the 4-pin ATX +12 Volt power cable, is plugged in tightly to the motherboard?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Processor.
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4820/DX4820nv.shtml
SATA power cable is plugged in tightly to your SATA harddrive?
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
If your SATA harddrive has provisions for plugging in a SATA power cable, and a 4-pin Peripheral power cable, BE SURE that only the SATA power cable is plugged in.
Plugging both in will fry out the harddrive. Maybe not right away, but will down the road.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Reply back in a Comment.
Jul 03, 2010 | Gateway DX4820-01 PC Desktop
Gateway desktop 506gr power issue narrowed down?
That was pretty unclear.  Is there a kind of burning symptom that suggests a short to you?  It seems to me that what happened is that either there was a power outage and your system thus shut down...all you'd have to to would be hit the computer's power button to turn it back on...or a fan somewhere died and therefore the system won't power up until you replace or repair that.  At least get a vacuum in there and brush out the dust so you can work.
What happened when you got a simplified system that 'worked'?  Was the power supply's fan spinning, at least?  What's the green light on, anyhow?
Jul 31, 2008 | Gateway 506GR PC Desktop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
