Question about Plasko-Tech, Inc Rotavision Rotating Storage Organization Device
Broken Cups - Rotovision
Hello, I would like to purchase extra cups. Where can I purchase the extra cups for the rotovision device? Thank you, Cham Felling chamf@socal.rr.com
How many pounds of strawberry to make 4 cups
By weight 4 cups= 32 ounces= 2 pounds. If you smash them, you will probably have to have an extra pound or two to fill those cups.
Jan 25, 2015 | Home
Need replacement cups for turbo chopper
where can I find cups for my turbo chopper express mt1070.a little plastic knob has broken off. I have three mixers tryng get replacement cups. I have small I need the larger ones. I have writtened the company that makes them NO answer
Nov 15, 2013 | Cook's Essentials 19-piece 250-watt Turbo...
Need tall cups....
If you're in the US, call Bella Cucina at 866/832-4843.
Jun 10, 2013 | Bella Cucina 13330 Rocket Blender
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
Sep 16, 2012 | Keurig B100 Coffee Maker
Hitachi Chime-O Matic-rice cooker/steamer RD 4056-need instruction book
#1. If you have "Long Grain" rice Ratio is 1 extra cup of Water ie: 2 cups of Long Grain Rice you add 3 cups of water.
#2: If you have "Short Grain " Rice is Equal Portions of Water to Rice, ie: 2 cups of "Short Grain " Rice then 2 cups of water.
Hope this Helps.
BT
Sep 02, 2010 | Zojirushi NS-MYC10 Neuro Fuzzy 5-Cup Rice...
Trying to open extra cups and courses
complete all the cups you have on rookie lvl to open up more cups. this is done in the grand prix.
play the candys challenges to unlock more characters
May 08, 2009 | Nintendo Donkey Kong Jet Race for Wii
Not getting all the water
its most likely evaperating cheaper models are known for this!
Dec 09, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Driveshaft repair '89 Laredo
1. Driving with just the front shaft is NOT adviseable. I would consider that choice as emergency only.
You are going to need a bench vise, a medium weight hammer, emery cloth, axle grease and a good amount of patience. You will first want to press out the old cups, done by clamping the drive shaft in the vise, next to the yoke. You must first decide what style of locks are used on the cups, either half moon rings, that lock from the inside, undereath the yoke, or the expansion type that lock from the top of the cup. Remove these old rings before removing the cups.
Either way these have to be removed. New locks will come with the new u-joints, and usually both types. After removing the old cups, it is important to clean all rust out of the area that holds the cups in the yoke. Also, remove any burrs that you might find there with a small, half moon file.. Key here is to clean, clean.
Next, before installing u-joint you must be sure that the new u-joint is installed 180 degrees out from the u-joint on the opposite end. This is called driveline timing. If this isn't done you will experience a serevre vibration while driving.
Next, apply extra grease in each of the new cups, which will hold the needle bearings in place while you install the cups. Before installing the new cups in the yoke, spray the cup area in the yoke with WD-40. This will aid in installation.
Now, carefully install a cup in yoke, gentle pushing or taping to get it started. Then insert the cross of the u-joint into the new cup. As the shaft is being held in the vise, install the second cup, and bring the cross into alignment between both cups in the yoke. Now tap gently on both cups, alternating from one side to the other, watching as the cups close over the cross ends.
Once you are satified they are in sufficently enough, you can use the vise to press the cups in the rest of the way. I always kept and used several sockets for this part. They were the right size to pass into the cups. Once the cups are seated all the way in, you can install the clips. If you find that the cups or cup won't seat all the way, you have managed to dislodge one of the needle bearings, (the reason for the extra grease), and you will have to disassemble and start the process all over again.
Once you have the u-joint installed properly, move it back and forth. There should be no binding. If there is, it means that a needle has dropped and the proceedure will have to be done all over again.
Hope this helps.
Bill
Nov 20, 2008 | 1989 Jeep Cherokee
Plasko-Tech, Inc Rotavision Rotating Storage Organization Device Logo
148 people viewed this question
Top Plasko-Tech, Inc Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Plasko-Tech, Inc Hardware and Accessory Expert? Answer questions, earn points and help others
