Question about Yamaha Dtxpress Iv Special Electronic Drum Set
No light in display on yamaha aw4416 - Yamaha Dtxpress Iv Special Electronic Drum Set
Keyboard display
try resoldering the flat cable on thescreen
Sep 22, 2014 | Yamaha Corporation Of America 88 Key...
Yamaha ypg 625 screen lights up, but no data
display screen might have very tightly screwd up bit loosen try for all of them
Dec 15, 2013 | Yamaha Music
Yamaha dgx-640 display
There is a small turning button on the back of the keyboard to change the screen tone and brightness,happend to me and this fixed it,i thought mine was broken too,till i spotted it
Oct 21, 2012 | Yamaha DGX 640 Keyboard Arranger
Factory reset for the yamaha aw4416 workstation
The original factory settings of the AW4416 can be restored by recalling Scene Memory '00'.
1) Press the [SCENE] button in the 'AUTOMATION' section.
2) Press the [F1] button to display the 'Scene Mem' page.
3) Turn the (DATA/JOG) dial to select '00.Initial Data' on the screen.
4) Press the yellow [ENTER] button.
Reference: Operation Guide, p. 203
Sep 09, 2012 | Yamaha Aw4416 Aw 4416 Workstation
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
Display is intermittend
Yamaha apparently had some problems with these displays according to the forums... If you are out of warranty then the repair will likely be at your expense. If in warranty, go on record immediately. Replacing the display is not really DIY unless you are electronically competent... I don't know what the cost for the display is, however you can call Yamaha America in CA and ask for "parts" and tell them what you need and ask the price. I can tell you there are a LOT of screws to remove to access the display and cables that must be cared for.
Mar 15, 2011 | Yamaha PSR-S500 Digital Keyboard
I HAVE A Yamaha PSR 260. About 8 years old. Recently it became defective.: Only the display lights up . No sound. No response to any button. When volume control is turned, I can hear the faint rustle on...
This MAY be due to a key contact or button that is STUCK "on".
Often this will freeze the controller.
Make sure power adapter is the correct one... underpowered or incorrect ones cause trouble.
Mar 20, 2010 | Yamaha Music
Yamaha Clavinova CVP-83S NO SOUND OUTPUT
clavinova 83s...comes on but goes off within 20 sec.,sometimes comes on display lights up but no sound or functions?
Apr 01, 2009 | Yamaha Full-Size Keyboard
Yamaha Dtxpress Iv Special Electronic Drum Set Logo
26 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
