Question about Sanyo DP32647 32 in. LCD TV
Sanyo DP32647 32 clicking sound - Sanyo DP32647 32 in. LCD TV
Sanyo Clicking/Ticking Sound
That is caused by the insulation on the EHT cable or tripler leaking.
Jun 12, 2017 | Televison & Video
It clicks on then clicks off
It sounds that the TV switches ON, and switches OFF, after three relay clicks. It is likely to the fault to its main board. Contact any service technician. This is not a user repairable fault.
google.com/+GopakumarGopalan
Nov 05, 2013 | Sanyo DP50747 50 in. Plasma TV
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Sanyo ds-25350 TV won't turn on, just clicks twice
Sanyo ds-25350 ? Not recognising that model number.
Sep 16, 2017 | Televison & Video
My Sanyo TV, 3 year old turns off with a click sound, as soon as it is turned On
Hi
your tv has defective power oscillation! the click sound that is relay power source. if the relay is click back you have defective small parts in power section! do you have experience in electronics?
Thanks!
Jun 22, 2008 | Televison & Video
TV making clicking sounds
if you had good color yes it is worth fixing sounds like your fly back trans former may be out see if you have any blown fusesif so get back tome for more help
Nov 02, 2007 | Sanyo DS31520 31" TV
Sanyo DP32647 32 in. LCD TV Logo
23 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
