Question about ASUS Computers & Internet
Universal serial bus connection is not working properly
drunkenkev
SOURCE: usb control
it still show unknown which i juess is unknown to which drivers are used for unknown
usb
Posted on Jun 08, 2008
pagebor
  • 2785 Answers
SOURCE: Universal serial bus controllers
no, the os will reload the drivers again
Posted on Sep 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cant connect to pc
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Posted on Dec 15, 2008
  • 401 Answers
SOURCE: how to remove if the universal serial bus is in write-protected?
TRY TEST DISK file:///D:/testdisk-6.11.3.win/testdisk-6.11.3/documentation.html
Posted on Mar 30, 2010
bronk50
  • 27725 Answers
SOURCE: Hi sir, I need help
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Posted on Jul 30, 2011
Ethernet controller and Universal Serial Bus (USB) Controller - The drivers for this device are not installed. (Code 28) What do I need this for, what can't I do or what goes wrong by not having these...
An Ethernet controller is a computer processing device used to handle network communications, and Universal Serial Bus (USB)
It can be used to connect keyboards, mice, game controllers, printers, scanners, digital cameras, and removable media drives, just to name, so i think you need booth device...install the 2 device? nothing it is goon to happen to your computer..
Sep 15, 2013 | Microsoft Windows 7 Home Premium Operating...
Muteki 7.2 I turn it on and it read 'USB FAIL'
It is such a hassle when your USB port doesn't seem to be working or when it does not read what's connected to your computer.
You might have a speaker, microphone, keyboard, mouse, webcam, digital camera, joystick or printer that are connected via a USB port.
You are sure you have the device properly connected, and you are confident all gadgets are working well, but still, you can't seem to make it work.
Initially, you need to plug and unplug the device to see if the connection is loose.
But if it still does not work, there are simple steps to fix your USB port.
Shut down the computer, then turn it back on to make sure the device (speaker, microphone, keyboard, mouse, webcam, joystick or printer) is properly connected.
Right click on "My Computer" and choose "Properties."
Click the tab that says "Hardware."
Choose "Device Manger."
Look for "Universal Serial Bus Controller" and click the plus sign before it.
Check if anything has a yellow question mark.
Having a yellow question mark means Windows has detected a problem.
Find your initial installer CD for your PC.
Place it in the CD drive, double click the USB drive and click "update device," and the driver will automatically be updated.
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Aug 13, 2013 | Computers & Internet
TS4GJF300 USB not recognised error 43 occurs
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Aug 28, 2012 | Transcend TS4GJF300 4GB JetFlash 300...
What stand for USB memory?
Hi
Universal Serial Bus.......
Aug 10, 2011 | Computers & Internet
The front 3 usb ports are not working along with all the card readers. In device manager they show to be working properly.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 08, 2011 | HP Pavilion a1130n (PX769AA) PC Desktop
Can't get my front USB bus to work properly!
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers or network adapters you should see a yellow question mark? right click to reinstall drivers
hope this helps
Oct 17, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I am using windows7 i cant connect my external drive
Using the mouse;
1. Click "Start" button, type “devmgmt.msc” (without quotes) in the “Search” bar and press "Enter". Click “Continue” if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Using the keyboard;
Again, disconnecting all USB devices
1. Press "Ctrl + Esc" to open the “Start” menu.
2. Type “devmgmt.msc” in the Search bar and press "Enter". Click “Continue” if necessary.
Try this first.
Jun 30, 2010 | SimpleTech SimpleDrive 160 GB External USB...
My USB connections have stopped working in my Compaq Presario, how can I fix it?
Check any USB device on the another laptop and then on this Laptop.
If it is not working then try to reinstall USB drivers.
Go to Device manager
Right click and Uninstall
follow the procedure on the all the devices under Universal Serial Bus controller.
Restart the laptop. check with the USB device again.
Hope this will help.Plz get back if this does not resolv ur issue.
May 23, 2010 | Compaq Presario R3000 Notebook
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
HP Office Jet J6480
HI,
Follow the steps to refrsh the USB connection which will resolve your problem.
=== Refresh USB Devices ===
Properties.
4. Click the (+) sign to the left of Universal Serial Bus controllers.
6. Click 'OK' to confirm the removal of the device.
NOTE: Repeat steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Computers & Internet Logo
12 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
