Question about ASUS Computers & Internet
Need to deguass - ASUS Computers & Internet
How do degaussing tv
There is a built in deguassing that you hear every time you turn on the tv. But to fix colour issues you need a hand held deguasser where you energize it and circle the whole picture tube from the front and then slowly back away while still making a wide circle.
Dec 01, 2013 | Televison & Video
Color not balanced. All kinds of color is showing. Old set
Your TV needs to be demagnetised. So all what is required is to use a hand held DEGUASSING unit with the set switched on and to be moved around the picture tube front.
If there is heavy coloration , the fault can also be a failure of the POSISTOR within - found near the mains power supply input in the board and which is responsible for auto deguassing every time the set is switched on.
You must replace if this is damaged or not working.
Oct 08, 2011 | Panasonic CT-32G34 34" TV
My 50 inch flat screen samsung lost all its color can it be fixed
If this is a CRT type Tv then it is best to have a DEGUASSING done on the set , is there is change then change the posistor for the deguassing coil. If not there is fault in the guns. You can charge the guns using a rejenuvating unit so as to increase the flow of electrons from the guns or also release any short in the coils.
If the picture tube is faulty the remedy can only be temporary and will not bring the true clarity to the TV.
finally a fault in the CHROMA section , failure of the crystal, the IC can be a suspect. Need to check on the IC voltages and signals/waveforms to confirm.
Sep 20, 2011 | Samsung Televison & Video
My son rubbed a magnet across the tv now the screen is blotchy
If you have not, turn off the tv and unplug from the wall for about thirty minutes or so.That will let it Degass.Hope that helps(bty don't get too upset at him as it does no harm other than causing that)
Apr 29, 2011 | Televison & Video
The light on the front blinks 5 times then 3 seconds off, the picture is horrible, it is washed out , sometimes very green sometimes very yellow, the focus is very poor around the outer ...
All symptoms shows picture tube is defective (weak in result) and giving no good picture result.
Its time for new tv as picture tube replacement would cost you more then tv worth.
Aug 26, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Deguassing problem on CM27101S
This problems deguassing coil can't be solved it entermittent problems happening,sometime the coil deguass,sometime don't.I had this tv before,this problems happen to me once in awhile,could never pindown what the parts was dead,I change many parts tries to solved this problems before.I change resistors,capacitors and transistors,never solved the problems.My experience using this tv,when the coil don't deguass,turn the tv off,turn it back on liike 15 mins later than coil well do it deguassing.
Jun 08, 2010 | Curtis-Mathis CM27101S TV
Damage on the picture tube, its a rainbow effect on the screen
try deguassing crt with deguassing coil. If this doesn't work the shadow mask has come loose inside the crt and the tv would need a new crt which would cost more than replaceing the tv
Jun 26, 2009 | Philips 27PT543S 27" TV
How do I deguassa VS-55601
Many manufacturers put a software degause feature in the main menu. There should be an option for deguassing, I am not a hundred percent on this model but if you look in your operations manual it will tell you if this option is available. If not you can purchase a deguaser at a local electronics supplier. It is basically a round donut shaped electro magnet use caution and follow the instructions. Remember in the future to always keep external speakers away from your TV sets..
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
Computers & Internet Logo
11 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
