Question about Staples SPLS242D Shredder
Spltxc22a will not shred although red light blinking
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Red light is blinking
Most home shredders overheat after a while, and stop working for 10, 15 minutes or more. It should reset once it cools down, as long as the blades aren't jammed with stuff that shouldn't be shredded.
Aug 27, 2014 | Office Equipment & Supplies
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
'Full light' blinks on and then off when you replace shred basket. Aurora AS1712x shredder. It's not full, won't work at all.
The sensor or button that tells it it's full, probably has paper dust or something jamming it. Clean it up without liquid and it will probably work.
Apr 24, 2009 | Office Equipment & Supplies
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Staples SPLS242D Shredder Logo
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
