Question about Apple Computers & Internet
Macbook screen goes white grid - Apple Computers & Internet
  • Andrew Roazen Dec 11, 2014
    Please add info as to which model of MacBook you're using including the year if you can.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 2,003 Answers
This could be due to a failing display panel.
Posted on Mar 03, 2015
2 Suggested Answers
  • 13 Answers
SOURCE: white screen of death on Macbook 13". when turning
You may need to reset the PRAM.
Start your computer and hold down the option, command (apple), P and R keys simultaneously until you hear the second chime. Then release.
This will reset the perimeter RAM (PRAM) and may allow your system to start, which it will do immediately if it capable.
If this is not the case and you have already tried removing the RAM and the HD, you may need to have the motherboard tested.
Posted on Mar 10, 2011
Mac tells me to shutdown by pressing the power button and the screen freezes
Your MacBook is over heating. You need to put some cooling paste to replace the old dried up paste that is on the processor and video card before it burns out the logic board. Clean out the fan while your doing this also.
Jan 10, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My screen goes white, but will go back to normal after touching screen
Normally you shouldn't touch the display at all. By touch the screen you are directly touching the LCD module. Touching it maybe causing the screen to fail.
You will need to replace the LCD module to fix this issue.
Dec 15, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
White screen of death on Macbook 13". when turning
Oct 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
InstallatIon of Mac OS X 10.4.10
White screen issues on your Macbook are more often than not, an indication that you may have a connected peripheral or device which may be hindering your Macbook's normal start up function
What you need to do first, is remove all peripherals from (printers, scanners, USB drives etc.) and then reboot your Macbook.
If your Macbook starts up normally without a white screen, leave all the peripherals disconnected and see if you can proceed to run all of your software updates, in Apple menu>Software Updates, first, including updating to the final version of Mac OS X 10.4 Tiger, 10.4.11.
Once all of your updates are completed, then you will need to go through a process of elimination by connecting one peripheral at a time, then properly shutting down and restarting your Macbook with each device, to see if your Macbook goes to a White screen.
Depending on the number of peripherals you have normally connected to your Macbook, this may seem a little tedious at first. But considering how bothersome a White screen is, it will be worth it solving the mystery of which peripheral is causing the white screen and failure to boot up normally.
If it turns out that one of the devices you had connected was in fact, causing the white screen, this will be the opportunity for to research online, visiting the affected device's manufacturer's website or even use Google, to confirm if there are any known issues and/or updates available to address that issue.
There are other variables which can come into view with a white screen issue, but this is a good way to start in terms of working toward a viable solution to this issue with your Macbook.
I hope this helps, let me know if you have more questions.
Regards,
-Mactechtrainer
Sr. Mac Support Specialist
Jan 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Dec 16, 2009 | Apple MacBook Air
Swapping MacBook Screens
As long as the lcd cable connects to the new screen it should work just fine. Just power it on before putting all the screws back to make sure.
In regards to the wireless I don't understand the question completely. The 2006 will probably only have two wires...just make sure they go where the white and black ones did. You'll just lose a lot of the "N" network strength.
Hopefully that answers you questions. If not, let me know.
--RescueTechLA
Nov 29, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Jul 12, 2009 | Televison & Video
Need new screen
you would have to order it online or go to the nearest apple store
Jun 05, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
42 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
