Question about Hip Street TITAN Tablet
I have a Titan pc 7028ME Tablet and the power button failed to function. what can i do?
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
Why wont tablet turn on?
First is it charged? Next press and hold the power button for about 15 seconds. Release. This a reset function. If you don't get any kind of flashing or some indication it's workding contact samsung help desk.
Aug 03, 2014 | Samsung Galaxy Tab Tablet PC
Restart MID M9000 9.0" Android 4.0 Tablet PC to have it functioning properly.
Try pushing the reset button in the TINY hole in the back of the tablet.
Oct 29, 2013 | Kocaso NEW MID M9000 9.0 " Android 4.0...
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Reset manual for royqueen tablet pc
1. Press the power button to get the option menu for
Power / Reboot / Silence option.
2. From that menu you'll have to hold down the Power button while holding down the Home button on the side of your tablet.
3. This brings up a menu to "Reboot Into Safe Mode" (These first 3 steps the manufacture fails to mention, which is where many users get stuck)
4. Hit yes for Safe Mode and then hold down both Power and Home buttons on side till the Dopo logo appears.
5. Release the buttons and hit the Power button one more time, then hold the Home button down till a menu option appears.
6. Use the Home button to move down to "Factory Reset" and press the Power button to select that option. Once it says "complete" then use the Power button to select "Reboot."
Jul 22, 2013 | Tablets & eReaders
Samsung galaxy tablet is frozen and the power would not turn off. What should I do ?
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
Apr 05, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Jan 17, 2009 | Gateway M275 Tablet PC
Hip Street TITAN Tablet Logo
108 people viewed this question
Top Hip Street Tablets & eReaders Experts
Are you a Hip Street Tablet and eReader Expert? Answer questions, earn points and help others
