Question about Ariens Garden
Ariens model 935335 hydro tractor leaking what appears to be grease or oil out of seal around the axle where it comes out of the transaxle also how to check fluid in the transaxle
    New Friend:
  • 19 Answers
Look for a dip stick it may be color coded with a yellow end or their may be a tag directing you to were it is located the seal may be bad
Posted on Apr 15, 2014
  • 11 Answers
SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
wilsodfarm
  • 986 Answers
SOURCE: My craftsman tractor model #
One thing you can try is to drain your fluid and refill with stp oil treatment,it not a perment fix but it will help you for now,and maybe you can trade,I have had this happen to me and it worked
Posted on Aug 29, 2010
I have a ariens rt 7020 7 hp. Model 901012, runs badly gas was coming out of carburetor , but there was oil that leaked out from around bottom of oil check tube, the oil is greenish in color.
Barbara, Sounds like carburetor may have dirt inside sticking float or worn needle and seat.Take mower into a good small engine shop, tell them what you have seen and have them diagnose and estimate repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 22, 2016 | Ariens Garden
Why doesn't it move forward or in reverse?
Many tractors and mowers have a key way on the axle and axle bore on the wheel hub.. Did you remove the tire and wheel from the mower axle? ..if you did most likely the drive axle key fell out of its slot on the drive axle and when you replaced the wheel it has no way to drive the wheels..try this start the mower put it in gear and try to move..have someone watch the end of the axle at the wheel
..if the key is missing the axle will be turning..but not the wheel..any good hardware store should carry them. just measure the depth and width of the key..something like 1/4,3/8 etc...good luck..
Aug 16, 2015 | Ariens Garden
How does the drive belt go around the pully system on an Ariens lawn tractor
Go to this site:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.5721913612416231&Site=ARIENSS
Aug 02, 2014 | Ariens Garden
Axle seal
There is a plug about halfway up in the transaxle, fill till lube runs out. You will need a new seal in the unit eventually, but if leakage is not real bad you can just add the oil recommended by the manufacturer. Hope this helps, plese post solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 14, 2014 | Ariens Garden
Ariens mod 93604200 hydro tractor won't shift
Check all of your hydraulic fluid levels - if OK, look at the fluid - is it dirty? If so, you're filter is plugged and needs to be changed. Then find out how/why the fluid is getting contaminated.
Nov 16, 2013 | Ariens Garden
Ariens 46'' 20 hp Hydro riding lawn mower user manual
my starter just clicks.I bought a new starter and it does the same thing
Jun 18, 2012 | Ariens Garden
How to adjust the clutch on ariens hydro 42
If you need the clutch adjusted there is a specific sequence for adjusting the clutch.I would spray with WD-40 or penetrating oil on the clutch movement , on the shaft (just in front of the engine) under the belts, there is only about 1/4" or so movement. Also lube all the linkage pivot points. If you still need to adjust the clutch download the manual with the model and serial number from Ariens.com and follow the procedures in the manual.
Apr 02, 2012 | Garden
My Ariens 1540 will not go anywhere. Engine starts and runs fine but suddenly pushing the steering levers does not make it go. Just got it from a person that says one of the Hydraulic units overheats and...
hi there rermortimer
have you made sure the bypass levers on box hyrdo boxs are disengaged ( that is in the drive mode ) not push / free wheel mode
here is web site to download a owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/ariens/915055_1944_915057_2148_915059_2352_915065_1540_915067_1740_915501_1844_915502_1540.html
in the manual it shows the levers at the rear of machine
it is possible that the units may have o/heated and dropped there additive pack and or the belt that drives the hydro boxs is slipping , check that the box has correct amount of oil and have no air entrained in the oil , ( if it does cavatation is highly possible ) especially if oil has got quite low
alot of heat can be generated from this condition and can damage the pump and motor units in the hydro boxs!!
cavatation sounds quite noisy , makes a knocky / rattley/ rumbly noise , vibration can be felt
in the drive system as air bubbles explode in the oil and is quite damaging to hydro units in itself
may need to drain and refill both units with top quality synthetic type oil which will handle tempreture better , then purge air from units but check simple things 1st
have a look let me know
cheers pauly46
Jun 14, 2011 | Ariens 34 In. Zoom Series Riding Mower
I have a yr old Ariens 27" deluxe snow blower. In our most recent storm I noticed an oil like fluid appearing to be leaking from the right side axle, behind the right tire. I supported the machine,...
mine did the same thing. i think it was just the grease melting. mine is now 4 years old and still works fine. yes i have opened that cover to regrease and check things out.
Jul 14, 2017 | Sport & Outdoor - Others
Garden Logo
300 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
