Question about Lennox ICOMFORT THERMOSTAT 49W95 Brand New
Lennox wifi themostat is not working - Lennox ICOMFORT THERMOSTAT 49W95 Brand New
Could you please give me the code for a Lennox HG31ES air conditioner? I have just bought a universal remote and haven't got the code. Regards Lynda
I doubt a 'universal remote control' will work for air conditioning. They are for televisions and DVD players.
If it is one of these, it should work out of the box.
Over 2000 CODES, OPERATES ALL LENNOX MODELS.
Full function universal remote control for all brands of air conditioners.
Large electric blue LCD backlight display. A product to satisfy all exigencies, with an attractive design and a full range of original brands covered.
Extremely easy to program with auto-search feature.
With over 2000 codes in the memory it makes this product the most complete on the market.
The big display with Backlight and clarity of indication of the functions complete the huge success of this product.
User manual included.
Supplied with wall mount bracket.
Remote control is gold in colour.
*Requires 2X AAA Batteries.
REPLACEMENT UNIVERSAL LENNOX AC AIR CONDITIONER REMOTE CONTROL FULL...
Or you could ask Lennox direct?
http://www.lennox.com/help
Dec 06, 2016 | Heating & Cooling
Is there some way to get the owner manual for the Lennox pro series LN7
lennox support page:
Easy access to Lennox product documents
LN7 didnt pull any results so you might want to double check the model #
Jun 08, 2015 | Pool & Spa
Is it normal for my furnace to have burner cycle once or twice
That sounds normal. When the bonnet reaches a preset temperature the burner turns off then when it cools down a bit the burner turns back on. Clean filters etc will help to keep the burner on longer in a cycle.
Aug 24, 2014 | Heating & Cooling
Need wiring diag for johnson control #G770-RJA-1
Is this on a Lennox gas furnace? If so you may be able to get one from lennox. Imay have one at work, but I won't be back there until Monday. bryan@reedwrightheating.com
Nov 19, 2009 | Heating & Cooling
I got a lennox xc13 air condtitioner,not blow cold air
When was the last time you checked or had the freon level checked.
Aug 02, 2009 | Heating & Cooling
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Lennox ICOMFORT THERMOSTAT 49W95 Brand New Logo
53 people viewed this question
Top Lennox Heating & Cooling Experts
Lawrence Oravetz
jeff5may32
tractorman44
tractorman44
Are you a Lennox Heating and Cooling Expert? Answer questions, earn points and help others
