Question about Keurig Platinum B70 Coffee Maker
What does prime mean
Prime is on the menu screen
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. A very common Keurig problem.
Posted on Sep 28, 2014
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
Screen displays "prime" and does not brew beverage, menu does not display
Mar 14, 2014 | Keurig Coffee Makers & Espresso Machines
Samsung 55inch plasma. Sound but no picture. Pushed menu button still no picture and menu does not appear.
Does the screen prime when you turn it on? By that I mean if you dim the lights in the room and turn on the set, does the screen slightly light up?
Oct 29, 2013 | Samsung HP-S5053 Television
My vizio 60' flat screen tv audio captioning for the blind will not turn off? A voice comes on during all prime time shows describing visual actions for the blind...help?
Go to your Menu options, and look around for a RESET option. You want to basically do a factory reset on your TV. (I'm assuming you turned off the setting, the system confirmed it, but it never turned off?)
Jan 31, 2013 | Televison & Video
What does the "prime" mean on the display screen
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
Menu screen keeps popping up instead of "ready to
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101;;'
Jun 11, 2011 | Keurig Special Edition B60 Coffee Maker
I accidentally hit the change language on my LG Prime phone to a language I cannot read. How do I reset my phone to English?
You can reset LG Prime to default setting by following these steps.
This will reset all user-defined settings on the device.
  1. From the standby screen, tap the Main Menu icon.
  2. Tap Settings.
  3. Scroll to and tap Phone Settings.
  4. Scroll to and tap Reset Settings.
  5. Tap Master Reset.
  6. Tap Yes to confirm.
  7. Enter Security code, tap OK. The default security code is 0000.
For details http://www.resetcellphone.com/solution/LG/gs390-prime
Jun 07, 2011 | LG Cell Phones
Error 5 message on lcd screen. What does this mean?
That means prime the water circuit. It should prime by itself. If the machine is making noise and still failed to prime, you can do it manually by going into test mode , set the multi valve to hotwater position and operate the pump . When the water flow freely turn off the machine and restart it. Hope it will help.
Jun 03, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
It won't brew and I am not sure on the menu screen
Hello Sewaters,
You should reset the coffee maker and make sure it's properly primed, as it's possible that the unit needs to be primed. Typically, the machine's malfunction when they lose their prime, as the water runs low, etc.
Here's the Quick Start Guide and Owners manual for your B60 Special Edition coffee maker.
http://www.keurig.com/help/B60_Quick_Start_insert.pdf?mscsid=KU26EG2D0SG28L5SS3CHXW66TC75AQUB
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf?mscsid=KU26EG2D0SG28L5SS3CHXW66TC75AQUB
Save a copy on your computer for future use and reference and you'll always have them available, when you need them again.
I hope you find this Very Helpful and best regards!
Dec 25, 2009 | Keurig B60 Coffee Maker
Machine says ventilate
Hi
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. Also check the steam tip. This can get plugged and prevent the pump from priming.
Make sure that you water hardness is set on 4 in the menu. Descale more often than not enough and you machine will last a long time.
Oct 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Keurig Platinum B70 Coffee Maker Logo
74 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
