Question about Philips 27PS60S 27" TV
25" Sharp tv
My 25" tv turned off by it self, it won't turn back on.
  • 143 Answers
Check fuses if the seconary fuse blown then posible bad fly back
Posted on Nov 02, 2007
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
My sharp LCD tv won't turn on,it goes off after a few seconds.
Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
Mar 13, 2013 | Televison & Video
My 32u-s650 tv won't turn on
Check for any loose solder terminals its main board.
Oct 20, 2012 | Sharp 32U-S650 32" TV
My 26" 1997 Sharp T.V. model #25H-M60 turns off by itself and won't turn back part of the time.
First thing if you are able is to unplug set and remove rear cover (lay set face down on a padded surface).
entire main board should be able to be seen or released so it slides out--take a very careful look at flyback and rest of board for any cracked or bad solder connections.
One bad connection (age) can cause this.
5_21_2012_3_10_50_pm.jpgtypical high voltage transformer which is also called a flyback transformer.
May 20, 2012 | Sharp 32L-S400 32" TV
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
My Aquos TV turned its self off and now it wont turn turn back on.
Turned off by itself means overheated in the circuits. If it is condensation, leave the standby on for a few weeks. Try using it to see if it will turn on for a short time.
Jan 03, 2011 | Sharp Aquos LC42BT10U 42 in. LCD TV
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Remote won't work and power switch pushed inside the television
No, sorry, not from this distance. But if I were actually there, I would try to put the switch back where it belonged, IF it was not broken!
May 15, 2017 | Sharp 25N-S100 25" TV
Screen goes white
you may have a solder joint or an electronic part that is beginning to fail. have an electronic expert look at it.
Feb 07, 2009 | Sharp 25R-S100 25" TV
Sharp 17" TV
It's the Closed Captioning function I think. I've had the problem with my Sharp TV (and other TV's that have Closed Captioning function). Look at the menu or the manual to see how to turn off Closed Captioning. It might be marked as "CC".
Oct 06, 2007 | Sharp 25N-M100 25" TV
Philips 27PS60S 27" TV Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
