Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Hydrostatic club cadet LT1045 brakes are locked
The brakes are locked it turns on but doesn't move. What do we need to unlock the brakes.
5 Suggested Answers
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
ToolBoxHero
  • 171 Answers
SOURCE: i don't want to talk to an expret , I lost my
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Posted on Jan 14, 2011
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 20 Answers
SOURCE: what the air pressure in front tires on a cub
check the side of the tires . it will tell you. szm230
Posted on Apr 15, 2011
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
http://data.manualslib.com/pdf/4/341/34016-cub_cadet/lt1045.pdf?6c17c6482511338711d5965e5bb6681c&take=binary
Apr 23, 2014 | Cub Cadet Garden
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
I own a Cub Cadet Hydrostatic Lawn Tractor, not sure of the model # (either LT1042, LT1045, LT0146 or LT1050). The engine runs, blades spin, but it doesn't move forward or backwards... Looking for...
Hello, W/D here.
Regards, --W/D--
Mar 07, 2011 | Cub Cadet Garden
Looking for when the oil and transmission should be changed on Lt
Hey,
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Brad:)
Sep 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Apr 22, 2009 | Garden
Lost manual. cant take the blades off and put on
use a block of wood in the discharge chute to keep the blades from turning, loosen them all before you take the blocked blade completly off
Mar 17, 2009 | Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
